I’m working on a 2023 Ford F-150 and recently swapped the column shifter to a stowable shifter. I purchased the shifter from eBay and installed it using the correct harness. The physical install went fine and everything is connected.
However, after the swap I’m getting a “Shift System Fail” message, along with a Hill Descent / Hill Start Assist fault.
My question is:
Do I need to make any changes using FORScan for this swap?
If so, which modules or as-built values need to be changed to properly configure the stowable shifter and clear these errors?
Any guidance from someone who has done this swap on a 2021–2023 F-150 would be greatly appreciated.
Thanks in advance.
