A few issues after upgrade.
I just updated my 2013 Flex to 3.0. Everything went well except I do not have climate controls, heated/cooled seats or the clock. I also forgot my usb hub on my desk so I have not installed that yet to be able to go to 3.4.
https://imgur.com/a/Z5mZTUA for the as built of the apim.
Old SYNC Version: 2.0
New SYNC Version: 17276
None
https://imgur.com/a/CFOf9B2
Did you do a Master Reset after installation?
Yes. I did not have any audio control at first. After the reset, audio control worked fine.
Climate control will not work properly on a CGEA 1.2 vehicle upgraded to Sync 3.0. There is no settings to make this work.
A 2013 Flex came with Sync 2 so this is a Retrofit. Copy your settings from a 2017 Flex as those had the same wiring and came with Sync 3.
Use this link to get the AB from a 2017.
- FordServiceInfo.Com
Than use this link to see what options you need to change.
Sync 3 APIM Database - CyanLabs
After you look this all over if you still have questions let us know.
Thanks Bill.
Now on 3.4 after using a 17 Flex as built. Everything working properly.
Thanks Bill.
Thats great to hear! Enjoy Sync 3, It’s far better than Sync 2.
