Accidentally installed non nav file
As per the topic I’ve accidentally installed a non nav file on my 2016 Lincoln mkx with nav. Is there a way to revert back to the proper file?
Old SYNC Version: 3.0.23219
New SYNC Version: 3.4.22200
Usb hub error and navigation fault
  Version: 3.4.22200
  Model: Kingston XS1000 SCSI Disk Device
  ; CyanLabs Syn3Updater 2.13.3.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
  FILES (4)
  [2025-08-13 9:02:44 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Keep Existing Maps
  [2025-08-13 9:02:44 AM] Install Mode: Auto-Detect (autoinstall) Forced: False
  [2025-08-13 9:02:44 AM] MY20 Protection: Auto-Detect
  [2025-08-13 9:02:44 AM] Formatting USB drive
  [2025-08-13 9:02:44 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
  [2025-08-13 9:02:51 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
  [2025-08-13 9:02:51 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
  [2025-08-13 9:02:51 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
  [2025-08-13 9:02:52 AM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
  [2025-08-13 9:02:52 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
  [2025-08-13 9:02:54 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
  [2025-08-13 9:02:54 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
  [2025-08-13 9:02:57 AM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
  [2025-08-13 9:02:57 AM] Preparing USB drive
  [2025-08-13 9:02:57 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
  [2025-08-13 9:02:57 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
  [2025-08-13 9:02:57 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
  [2025-08-13 9:02:57 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
  [2025-08-13 9:02:57 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
  [2025-08-13 9:02:57 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
  [2025-08-13 9:02:59 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
  [2025-08-13 9:03:00 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
  [2025-08-13 9:03:00 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
  [2025-08-13 9:03:00 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
  [2025-08-13 9:03:03 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
  [2025-08-13 9:03:05 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
  [2025-08-13 9:03:05 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
  [2025-08-13 9:03:05 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
  [2025-08-13 9:03:09 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
  [2025-08-13 9:03:13 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
  [2025-08-13 9:03:13 AM] Generating Autoinstall.lst
  [2025-08-13 9:03:13 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
To update this, I’ve managed to update to 3.4.23188 however, I still get the navigation and usb hub error. To clarify, on the original 3.0.23219 I was running I had none of the above errors. Any information you guys have would be greatly appreciated.
Thanks
Firstly you need to get the later hub which supports Apple Car Play…a search will get you purchase details.
Also you need to do a master reset if not done as this normally solves nav issues.
Did you install the NAV and NAV VOICE files?
I have installed the Nav and Nav voice files. That part appears to be working now, however, every once in a while it tells me “usb hub not supported” of which it worked fine before and still eventually finds my AAwireless and connects
You need to replace the hub. There is no way around this as no 2016 came with a hub that supports CP.
