Hi, I just did the sync 2 → sync 3 conversion. I still have some issues with bluethooth communication and I found a guide on how to solve this via forsscna programming on the ACM.
Problem is that the ACM programming interface via Forscan does not look as it should be. Instead of having the multiple HEX line of code as per your database, i just have a 4 bit line 727-01-01. All other lines are missing…
It seems I can only program a fraction of the ACM. What could be the issue?
Additional info:
I have forscan with extended license
ACM version: F1BT18C815-GG
Update: I tried rebooting the ACM module, change Forscan configuration, delete car profile to retrigger module reading. No change so far. Maybe this is a connection error? (e.g. a connector on ACM is not plugged properly)
