Background information:
The car was imported from the USA to Ukraine.
Localization was installed.
Yesterday, I decided to update the firmware. I prepared the update via Synk 3 updater.
Version: 3.4.23188
Install Mode: Auto-detect (downgrade)
My20 Protection Enabled: Disabled / not MY20
; CyanLabs Syn3Updater 2.14.2.0 Stable - downgrade Mode - Sync 3.4.23188 EU
I inserted the flash drive, and the system displayed “automatic update.”
At that moment, I accidentally knocked the flash drive, and it fell out ![]()
I turned off the car, turned it back on, the screen went black, I inserted the flash drive again, and after about a minute, the system said “Russian language installed.” That was the end of it.
What I tried to do:
- Soft reset with buttons
- Disconnecting the negative battery terminal
- Removing the F17 fuse
- Inserting a flash drive with the original firmware (USA/Canada)
What are the options for reviving the system? If there are any…
Old SYNC Version: 3.4.21194
The system did not display any errors.
Operating System: Майкрософт Windows 11 Pro (2009)
Version: 3.4.23188
Install Mode: Автоопределение (downgrade)
My20 Protection Enabled: Отключено / не MY20
FILES (8)
1u5t-14g386-cb.tar.gz (8,5MB)
[23.11.2025 15:21:14] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: F13 (2024) - EU (09 2025)
[23.11.2025 15:21:14] Install Mode: Автоопределение (downgrade) Forced: False
[23.11.2025 15:21:14] MY20 Protection: Отключено / не MY20
[23.11.2025 15:21:14] Formatting USB drive
[23.11.2025 15:21:14] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[23.11.2025 15:21:57] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[23.11.2025 15:22:06] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:06] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[23.11.2025 15:22:06] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[23.11.2025 15:22:06] Checking Existing File: 1u5t-14g386-cb.tar.gz
[23.11.2025 15:22:07] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[23.11.2025 15:22:07] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[23.11.2025 15:22:07] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:07] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[23.11.2025 15:22:21] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:21] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[23.11.2025 15:22:28] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:28] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[23.11.2025 15:22:28] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:28] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[23.11.2025 15:22:38] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[23.11.2025 15:22:38] Preparing USB drive
[23.11.2025 15:22:38] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[23.11.2025 15:22:38] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[23.11.2025 15:23:11] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[23.11.2025 15:23:32] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[23.11.2025 15:23:32] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[23.11.2025 15:23:32] Copying: GB5T-14G386-SC_85041.tar.gz
[23.11.2025 15:23:32] Validating: GB5T-14G386-SC_85041.tar.gz
[23.11.2025 15:23:32] Copied: GB5T-14G386-SC_85041.tar.gz
[23.11.2025 15:23:32] Checking Existing File: 1u5t-14g386-cb.tar.gz
[23.11.2025 15:23:32] Copying: 1u5t-14g386-cb.tar.gz
[23.11.2025 15:23:32] Validating: 1u5t-14g386-cb.tar.gz
[23.11.2025 15:23:32] Copied: 1u5t-14g386-cb.tar.gz
[23.11.2025 15:23:32] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[23.11.2025 15:23:32] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[23.11.2025 15:23:32] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[23.11.2025 15:23:32] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[23.11.2025 15:23:33] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[23.11.2025 15:23:33] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[23.11.2025 15:26:03] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[23.11.2025 15:27:04] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[23.11.2025 15:27:04] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[23.11.2025 15:27:04] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[23.11.2025 15:28:11] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[23.11.2025 15:28:40] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[23.11.2025 15:28:40] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[23.11.2025 15:28:40] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[23.11.2025 15:28:45] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[23.11.2025 15:28:47] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[23.11.2025 15:28:47] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[23.11.2025 15:28:47] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[23.11.2025 15:30:27] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[23.11.2025 15:31:10] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[23.11.2025 15:31:10] Generating reformat.lst
[23.11.2025 15:31:10] Generating autoinstall.lst
[23.11.2025 15:31:10] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
