Sharing some of the configuration possibilities on the C-Max Hybrid using Forscan. If you know about more possible configurations, please let me know!
TO GET YOUR COUNTRY CODE:
CONVERT YOUR COUNTRY CODE TO HEX USING THIS:
Convert hexadecimal to text - Converters - Hex/Text Convertor
The country code converter is built into the CyanLab Asbuilt Databases where appropriate. Be aware that Ford uses the coding in the converter here. There are more than one country code tables in use on the internet, and they are not all the same.
Here is an example:
Thank you for the information. This is also contained in the asbuilt databases here on the site.
Hi, yes that database is mainly what I used, however the main focus of this thread is for me and others aswell to learn which configuration changes/modifications actually have an effect in general… Also some of the databases are unclear to what they do so that’s sort of why
