I almost successfully upgraded my 2013 Focus ST from Sync1 to Sync3. Everything, except the Rear Camera, is working fine. I checked the wiring on the APIM Connector, should be fine. Enabled the camera in ForScan (the donor car didn’t have a camera) but Sync3 just tells me “Camera unavailable”.
Thank you for your answer.
No, I haven’t bought a harness, I repinned everything myself. Before I switched from Sync1 to Sync3, I used a Xtrons Android Radio and for the rear camera I had to use an adaptor cable to connect it. Switching to Sync3 I just cut the adaptor cable and pinned the wires to the APIM Connector, according to the tutorial on the focusowners forum.
Forscan gives me an C1001:01-0B “General electrical failure” error. I’ll check the wiring between the APIM Connector and the boot next week, when I get home again. I already checked the fuse, which is okay.
