Can't create USB
I get the following error when trying to create the USB drive using the Sync3 Updater: Unable to read data fromt he transport connector: An established connetion was aborted by the software in your host machine. This was after I disabled the screen saver and the machine sleep in setttings. Prior to this I was getting Error: The remote name could not be resolved. “ivsu.binaries.ford.com
Old SYNC Version: 3.023219
I am unable to do that at the moment. This interface is wonky and on another computer separate from what I was using.
That’s a local network error on your internet connection, not an issue with the updater
As said before, not a Syn3updater issue.
There’s something on your computer that’s preventing the connection, so:
  • try a different computer
  • try a different network
  • try a different computer on a different network
I rebooted my router a couple of times and it finally made it all the way through he download. I imaged my F150 and all is well!
Many thanks. I will post. A reply to myself.
Many thanks for the support. I rebooted my router a couple of times and this enabled the downloads and the transfer to the USB stick. The transfer to the 2018 Ford F150 Platinum worked seamlessly.
If that’s the case, my guess is you managed to change your public IP provided by your ISP by rebooting the router, maybe your old IP was blocked or something…
Anyways, glad it worked, but keep that in mind in the future, your ISP may work against you :grinning_face:
