Can't get rid of pop up "Installing updates. Do not remove USB.. blah blah blah..." almost every startup
Hello everyone.
Trying to get rid of that anoying pop up that I see and have to press on touchscreen almost everytime I start my Ford C-max. The popup was before update and stayed after update with reformat. After updating tried remove and readd Garcenotes with autoinstall, did nothing too. What else do I missing? Please help.
Old SYNC Version: 3.0.19205
no error message
VIN: 1FADP5EU3HL108280
APIM Model: Unknown
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 4.3G
Version 3.4.23188 (NU5T-14G381-AD)
2025-11-03 20:42:30 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 13M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.8M / 937M
/fs/sd/MAP/ = 8.5M / 1.3G
/fs/sd/MAP/ = 14M / 1.7G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 7.2M / 1.4G
/fs/Nuance/ = 16M / 1.6G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 25M / 2.6G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 903M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 88M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 4.3G / 25G
Installed Packages
4U5T-14G421-CJD
4U5T-14G421-CHD
4U5T-14G421-CGD
4U5T-14G421-CFD
4U5T-14G421-CED
4U5T-14G421-CDD
4U5T-14G421-CCD
4U5T-14G421-CBD
4U5T-14G421-CAD
5U5T-14G391-CS
4U5T-14G422-CAJ
4U5T-14G422-CBJ
4U5T-14G422-CCJ
4U5T-14G423-CC
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
Did you do a master reset after your upload of the latest version?
For the Sync app ONLY.
Downgrade the Sync version to 3.4.21265 and then back to 3.4.23188. For some reason the update flag is not clearing.
Yes I did. Nothing changed.
I do this with USB flash created with Sync3 Updater with lower version and in options change install mode to “downgrade” ?
No, use autoinstall.
Still getting popup :frowning:
Run the Interrogator Utility and post the XML file here…
APIM Model: Unknown
APIM Size: 32GB
2025-11-08 11:45:45 +00:00
/fs/rwdata/ = 895M / 1.2G
Installed Packages
4U5T-14G421-CJD
4U5T-14G421-CHD
4U5T-14G421-CGD
4U5T-14G421-CFD
4U5T-14G421-CED
4U5T-14G421-CDD
4U5T-14G421-CCD
4U5T-14G421-CBD
4U5T-14G421-CAD
5U5T-14G391-CS
4U5T-14G422-CAJ
4U5T-14G422-CBJ
4U5T-14G422-CCJ
4U5T-14G423-CC
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
The storage looks fine, but the Interrogator Utility doesn’t pick up your asbuilt info. Looking at your OEM asbuilt, The Sync 3 APIM should be a HP5T-14G371-CCA. Unfortunately you have a firmware version that is a known issue from Ford, GB5T-14G374-CB. This file should be replaced with GB5T-14G374-CD. You will need to use the paid license version of FORScan to program firmware. Or live with the notification…
1FADP5EU3HL108280.ab (31.0 KB)
7D0
F110>DSGB5T-14G371-CB
F111>HP5T-14G380-BA
F113>HP5T-14G371-CCA
F124>GB5T-14G375-CA
F141>VW3WCR1R
F188>GB5T-14G374-CB
F18C>������������������������������������������������
F1D0>38:D2:69:64:51:FB
F1D1>38D2696451FC
Your OEM APIM Asbuilt is:
7D0-01-01 2328 6402 800A
7D0-01-02 0288 1680 0A04
7D0-02-01 4C48 0106 C035
7D0-02-02 8200 1000 006D
7D0-02-03 0005 E1
7D0-03-01 0001 0000 00DC
7D0-04-01 0100 0401 04E6
7D0-04-02 0001 DE
7D0-05-01 17A2 1798 286D
7D0-05-02 BE9C
7D0-06-01 805E
7D0-07-01 1104 3300 0027
7D0-07-02 0000 0682 0068
7D0-07-03 0004 306A 007F
7D0-07-04 6446
7D0-08-01 0000 0000 00E0
7D0-08-02 0000 0000 00E1
Thanks for your efforts and clarification. I’m thinking about committing to this procedure :slight_smile: What hardware do I need? What are the steps to do this? Risks? Thank you in advance.
