# Can't get rid of pop up "Installing updates. Do not remove USB.. blah blah blah..." almost every startup
**URL:** <https://community.cyanlabs.net/t/cant-get-rid-of-pop-up-installing-updates-do-not-remove-usb-blah-blah-blah-almost-every-startup/23935>\
**Category:** CyanLabs Update Support\
**Tags:** oem, nav, na, APIM, SYNC3, pre-my20\
**Created:** [3 November 2025 18:59 UTC](https://community.cyanlabs.net/t/cant-get-rid-of-pop-up-installing-updates-do-not-remove-usb-blah-blah-blah-almost-every-startup/23935 "2025-11-03T18:59:02Z")\
**Posts on this page:** 1\
**Showing post:** 11
<div class="post-metadata">
**Author:** ![F150Chief](https://community.cyanlabs.net/user_avatar/community.cyanlabs.net/f150chief/32/14712_2.png) [@F150Chief](https://community.cyanlabs.net/u/F150Chief)\
**Post date:** [13 November 2025 22:54 UTC](https://community.cyanlabs.net/t/cant-get-rid-of-pop-up-installing-updates-do-not-remove-usb-blah-blah-blah-almost-every-startup/23935/11 "2025-11-13T22:54:43Z")
</div>
> [@FORScan Software Version 2.4.x Releases and Information, 2.4.20 beta, 2025-11-10](https://community.cyanlabs.net/t/forscan-software-version-2-4-x-releases-and-information-2-4-20-beta-2025-11-10/4043):
> Added notes below for purchasing the Extended License. FORScan 2.4.20 is a public release. [Link to download v2.4.20 beta](https://forscan.org/download/42y/FORScanSetup2.4.20.beta.exe) Changelog (full change history can be found in FORScan.Changelog.2.4.txt available in the FORScan installation folder): 2.4.20 beta, 2025-11-10 v2.3.68 functionality Firmware database update adjusted firmware flash sequence for IPMA Fusion and similar (-14G019-, -14G024-, -14G081-, -14G082-) bug: missing Signal Configuration F108 firmware files (bug appeared in 2.4.1…
> [@APIM Firmware Flash Rescue](https://community.cyanlabs.net/t/apim-firmware-flash-rescue/4691):
> APIM Firmware Flash Rescue Read this document fully before starting any actions. It is your responsibility to follow the instructions as outlined below. This document applies to 2016 thru 2019 (G, H, J, K) APIM’s only. This document does not address, or should the procedures be used on MY20+ APIM’s unless it is confirmed that it is safe to do so. The procedures contained in this document are specifically for North American (US) APIM configurations to rescue a ‘bricked’ APIM due to an unsucce…
_[View the full topic](https://community.cyanlabs.net/t/cant-get-rid-of-pop-up-installing-updates-do-not-remove-usb-blah-blah-blah-almost-every-startup/23935)._
