I upgraded my 2015 Ford Explorer to a Sync 3.4 system.
I looking for the setting, that when you adjust the temperature up or down, that the pop will display over the sync system to show you the new temperature. Currently I have to get out of airplay mode, and go to the ford screen to see it. My F350 does this, and I’d like to enable it on my Explorer. I just can’t find the setting in the APIM for this feature.
What is your SYNC Region? North America
What is your current SYNC Version? 3.4
Do you have Navigation? Yes
Non
This might be a Climate or Temperature Repeater setting in the APIM. However, the 2015 Explorer may be different from the F350 as far as climate and vehicle architecture. (CGEA 1.3/1.2) The settings are dependent on the hardware, single or dual zone. I would look at the asbuilt info for both APIM modules and compare the climate settings.
The climate and temp repeater settings are at 7D0-04-01 xxxx xx*x xxxx
Climate Domain, Fan Repeater (FR), Temperature Repeater (TR)
0=Climate Domain On (Automatic), Fan Repeater On, Temperature Repeater On
8=Climate Domain Off (Manual), Fan Repeater On, Temperature Repeater On
2=Climate Domain On (Automatic), Fan Repeater On, Temperature Repeater Off
A=Climate Domain Off (Manual), Fan Repeater On, Temperature Repeater Off
4=Climate Domain On (Automatic), Fan Repeater Off, Temperature Repeater On
C=Climate Domain Off (Manual), Fan Repeater Off, Temperature Repeater On
