Hi friends i have problem with my 3.4 updating 20021,after the update the clock in the sync 3.4 not correct with real time and i can fix it.i tried by APIM RESET & IPC RESET & MASTER RESET nothing happened.please help
Try set clock time to gps time or if that don’t work try to manually change it to your desired time, hope this helped.
Check
Stereo Extended Play (EP) Stereo Extended Play Time (EPT) Clock Master (CM) 10 Minute Clock (MC) CAN Steering Wheel Control Switches (SWC)
on https://cyanlabs.net/ford-apim-asbuilt-db/
you likely need to change the “Clock Master”
thank you for your responding
thank you so much for your responding
So was the issue resolved? What fixed it?.
Not yet because im in duty now when i go back to home i will try it to fix it.
