Does anyone know what USB hub model a MC5T-14F014-AC is from?
I’m trying to upgrade a 2019 Fusion Titanium from the dual A ports to a C and A port. I’m thinking it’s a later revision from a 26 Escape or Maverick because the dimensions match the fusion hub but I cant find much about that model number. Hoping somebody here knows what I’m looking at.
2021
I searched another part of the model number and the K7EDB brought up Maverick hubs so I figured, any compatibility issues I know the early mavericks used Sync 3.0 or should it just plug and play?
The USB A/C module compatibility varies by the firmware in the APIM, the Mavericks when they rolled out had 3.4 not 3.0 and would have had -Ex firmware in the APIM.
The 2019 Fusion would have had -Dx firmware in the APIM so it may or may not work.
I did update using Fords update file to 3.4.23188 then Cyans labs to keep the maps fresh so now it’s on 3.4.26057. I started looking because android auto started giving her a usb device not supported for a first boot, so I was just going to upgrade the hub since she wanted a C-port anyway.
Look at the firmware level in ForScan not the Sync build level, they’re 2 entirely different things.
Sync doesn’t support external USB hubs, only direct connections to the port.
If you have a direct connect, did you do a master reset after doing the reformat to load the map set and .26057?
Have you tried another good quality cable or using the other USB port?
Yep we even tried taking the hub out to clean it and check for debris, I can’t use forscan because I’ve never got around to getting the USB to OBD adapter which is on me. It doesn’t even affect the function it pops the error then still loads Android auto anyway but it’s starting to annoy the wife.
Try dropping back to 3.4.23188, and see if that clears your problem.
3.4.26057 is still a dealer only install with Ford for some models.
You don’t have to reformat, just pick a 3.4.x version as current, select 3.4.23188 as target, deselect everything but the APP since Gracenotes and voices are the same.
