Downgrade 3.4.23188 error VER_ERR08
Hi there! I’ve tried to downgrade my SYNC 3(2020 year) to get clean raw data, but got an error VER_ERR08.
4 month ago I’ve updated SYNC to 3.4.23188 via official site. This winter started to observe a strange behavior of SYNC3 like a dark display when start the car, do not turn off the display after closing car. Also sync does not save my settings like language.
Install Type: Unknown
Old SYNC Version: 3.4.23188
VER_ERR08
Operating System: Майкрософт Windows 11 Домашняя (2009)
Version: 3.4.23188
Install Mode: downgrade (downgrade)
Install Mode Overridden: True
My20 Protection Enabled: Отключено / не MY20
Model: Innostor Innostor USB Device
; CyanLabs Syn3Updater 2.14.2.0 Stable - downgrade FORCED  Mode - Sync 3.4.23188 EU
FILES (8)
1u5t-14g386-cb.tar.gz (8,5MB)
[19.05.2026 9:44:55] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Сохранить существующие карты
[19.05.2026 9:44:55] Install Mode: downgrade (downgrade) Forced: True
[19.05.2026 9:44:55] MY20 Protection: Отключено / не MY20
[19.05.2026 9:44:55] Formatting USB drive
[19.05.2026 9:44:55] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[19.05.2026 9:45:03] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:45:03] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:45:30] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:45:32] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:45:32] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:45:32] Downloading: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:45:32] Validating: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:45:32] Downloaded: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:45:32] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19.05.2026 9:45:32] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[19.05.2026 9:45:32] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.05.2026 9:45:32] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[19.05.2026 9:45:32] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.05.2026 9:45:37] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[19.05.2026 9:45:37] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19.05.2026 9:45:40] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[19.05.2026 9:45:40] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19.05.2026 9:45:40] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[19.05.2026 9:45:40] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.05.2026 9:45:43] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[19.05.2026 9:45:43] Preparing USB drive
[19.05.2026 9:45:43] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:45:43] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:46:12] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:46:26] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[19.05.2026 9:46:26] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:46:26] Copying: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:46:26] Validating: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:46:26] Copied: GB5T-14G386-SC_85041.tar.gz
[19.05.2026 9:46:26] Checking Existing File: 1u5t-14g386-cb.tar.gz
[19.05.2026 9:46:26] Copying: 1u5t-14g386-cb.tar.gz
[19.05.2026 9:46:27] Validating: 1u5t-14g386-cb.tar.gz
[19.05.2026 9:46:27] Copied: 1u5t-14g386-cb.tar.gz
[19.05.2026 9:46:27] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.05.2026 9:46:27] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.05.2026 9:46:27] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.05.2026 9:46:27] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.05.2026 9:46:27] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.05.2026 9:46:27] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.05.2026 9:48:06] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.05.2026 9:48:46] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.05.2026 9:48:46] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19.05.2026 9:48:46] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19.05.2026 9:49:26] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19.05.2026 9:49:44] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[19.05.2026 9:49:44] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19.05.2026 9:49:44] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19.05.2026 9:49:49] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19.05.2026 9:49:50] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[19.05.2026 9:49:50] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.05.2026 9:49:50] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.05.2026 9:50:44] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.05.2026 9:51:06] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.05.2026 9:51:06] Generating reformat.lst
[19.05.2026 9:51:06] Generating autoinstall.lst
[19.05.2026 9:51:06] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
You are lucky that error is all you got, you are apparently trying to reformat a MY20 APIM, which will brick the unit. DO NOT Reformat this APIM.
why? After 3-4 soft resets, the raw data was cleaned, and Sync was successfully updated
Good afternoon and many thanks to the team…for all the dedication and effort on behalf of the community. I updated…it went very well, successfully. I can’t see the differences. If anyone could please help, I would be grateful. Thank you very much. From Portugal.
Why? Because a 2020 year or newer APIM uses different drivers for some of the components and if you reformat it with the cyanlabs syncupdater you will lose those drivers and the unit becomes a door stop.
You indicated that you were using a 2020 or newer APIM
FMods has a universal updater you can use on a 2020 or newer APIM but it comes with some prerequisites to use it.
checked again. by document my car produced in 2020, but I see all components produced in 2019. Looks like that is the reason why I successfully updated my Sync.
There are L-series APIM’s with the older version eMMC, but they were very early 2020 production. I have one for testing. The Interrogator Utility will identify these as L-series part number with the old version eMMC part numbers.
Looks like yes, all component produced in 2019, but the car at the begining of 2020. The topic can be closed, now everything works well.
