Explorer 2017 Music (FM / AM / BT) Stopped Playing
I upgrade to Sync 3.4 a year or 2 ago, and it ran great for a while. A few weeks ago, some strange popup messages started to appear when we started the radio like the radio was completely rebooted everytime the car started (turning on usage statistics, 911 stuff, auto upgrade and stuff like that). Today, the music stopped working all together on all sources. It still makes sounds (beeps). I tried to upgrade it to the latest 3.4, and no fix. I did a master reset and finally got the music back on. But after I turned off the car and turned it back on, it was sadly silent again. Any thoughts?
Old SYNC Version: 3.4.22251
New SYNC Version: 3.4.2388
Version: 3.4.22251
Model: Mass Storage Device USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.3.19052 NA
Item2 = APPS - 4U5T-14G381-AN_1552583626000.TAR.GZ
Item3 = VOICE - 4U5T-14G391-CJ_1552513842000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G391-CJ_1552513842000.TAR.GZ
Item4 = GRACENOTES - 4U5T-14G423-CA_123766.tar.gz
Open4 = SyncMyRide\4U5T-14G423-CA_123766.tar.gz
FILES (4)
4U5T-14G391-CJ_1552513842000.TAR.GZ (381.5MB)
[5/5/2024 4:46:53 PM] Selected Region: NA - Release: Sync 3.3.19052 - Map Version: Keep Existing Maps
[5/5/2024 4:46:53 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[5/5/2024 4:46:53 PM] MY20 Protection: Auto-Detect
[5/5/2024 4:46:53 PM] Formatting USB drive
[5/5/2024 4:46:53 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[5/5/2024 4:47:00 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/5/2024 4:47:00 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[5/5/2024 4:47:00 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/5/2024 4:47:01 PM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[5/5/2024 4:47:01 PM] Checking Existing File: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:47:01 PM] Downloading: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:47:18 PM] Validating: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:47:19 PM] Downloaded: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:47:19 PM] Checking Existing File: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:47:19 PM] Downloading: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:47:53 PM] Validating: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:47:54 PM] Downloaded: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:47:54 PM] Preparing USB drive
[5/5/2024 4:47:54 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/5/2024 4:47:54 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/5/2024 4:47:54 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/5/2024 4:47:54 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/5/2024 4:47:54 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/5/2024 4:47:54 PM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/5/2024 4:48:23 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/5/2024 4:48:24 PM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/5/2024 4:48:24 PM] Checking Existing File: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:48:24 PM] Copying: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:48:47 PM] Validating: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:48:48 PM] Copied: 4U5T-14G391-CJ_1552513842000.TAR.GZ
[5/5/2024 4:48:48 PM] Checking Existing File: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:48:48 PM] Copying: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:49:32 PM] Validating: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:49:34 PM] Copied: 4U5T-14G423-CA_123766.tar.gz
[5/5/2024 4:49:34 PM] Generating Autoinstall.lst
[5/5/2024 4:49:34 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
This sounds like a failing APIM. The sound comes from the ACM and it can work without the APIM in some cases.
This also could be a bad battery or charging system issue.
It’s unclear which version the unit is running now, the information you provided is contradictory, so clarify that.
Sorry, the logs were from a downgrade attempt I made after I updated. That didn’t work (didn’t recognize the usb with the older version).
The current version is 3.4.23188
Per the logs and the GB size it looks like you’re trying to use a USB hard drive and those will not work.
You MUST use a 32GB thumb drive and make sure it is a quality brand like Sandisk. Try again with a USB stick.
Ok, please create and run an interrogator log against the unit and share the produced XML file with us.
Reflashed everything with a 32gig sandisk.
Gonna do an interrogator log next
Here is the log:
Version: 3.4.22251
FileSystem: FAT32
; CyanLabs Syn3Updater 2.12.5.0 Stable - downgrade Mode - Sync 3.4.23188 NA
FILES (20)
[5/6/2024 4:50:13 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.22 (2022) - NA (06 2022) (Updated Voice)
[5/6/2024 4:50:13 PM] Install Mode: Auto-Detect (downgrade) Forced: False
[5/6/2024 4:50:13 PM] MY20 Protection: Auto-Detect
[5/6/2024 4:50:13 PM] Formatting USB drive
[5/6/2024 4:50:13 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[5/6/2024 4:50:21 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/6/2024 4:50:22 PM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:22 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[5/6/2024 4:50:22 PM] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[5/6/2024 4:50:22 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[5/6/2024 4:50:22 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[5/6/2024 4:50:22 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/6/2024 4:50:22 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:22 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/6/2024 4:50:23 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:23 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/6/2024 4:50:24 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:24 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/6/2024 4:50:27 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:27 PM] Checking Existing File: 4U5T-14G421-CJF_1682462901000.TAR.GZ
[5/6/2024 4:50:28 PM] Validated: 4U5T-14G421-CJF_1682462901000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:28 PM] Checking Existing File: 4U5T-14G421-CHF_1682462859000.TAR.GZ
[5/6/2024 4:50:31 PM] Validated: 4U5T-14G421-CHF_1682462859000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:31 PM] Checking Existing File: 4U5T-14G421-CFF_1682462169000.TAR.GZ
[5/6/2024 4:50:34 PM] Validated: 4U5T-14G421-CFF_1682462169000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:34 PM] Checking Existing File: 4U5T-14G421-CGF_1682462518000.TAR.GZ
[5/6/2024 4:50:36 PM] Validated: 4U5T-14G421-CGF_1682462518000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:36 PM] Checking Existing File: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[5/6/2024 4:50:39 PM] Validated: 4U5T-14G421-CEF_1682461522000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:39 PM] Checking Existing File: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[5/6/2024 4:50:42 PM] Validated: 4U5T-14G421-CDF_1682463264000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:42 PM] Checking Existing File: 4U5T-14G421-CCF_1682461368000.TAR.GZ
[5/6/2024 4:50:45 PM] Validated: 4U5T-14G421-CCF_1682461368000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:45 PM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[5/6/2024 4:50:47 PM] Validated: 4U5T-14G421-CBF_1682461295000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:47 PM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[5/6/2024 4:50:50 PM] Validated: 4U5T-14G421-CAF_1682461100000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:50 PM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[5/6/2024 4:50:50 PM] Validated: 4U5T-14G424-CF_1682464057000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:50 PM] Checking Existing File: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[5/6/2024 4:50:53 PM] Validated: 4U5T-14G422-CAM_1682463335000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:53 PM] Checking Existing File: 4U5T-14G422-CBM_1682463581000.TAR.GZ
[5/6/2024 4:50:54 PM] Validated: 4U5T-14G422-CBM_1682463581000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:54 PM] Checking Existing File: 4U5T-14G422-CCM_1682463747000.TAR.GZ
[5/6/2024 4:50:56 PM] Validated: 4U5T-14G422-CCM_1682463747000.TAR.GZ (Skipping Download)
[5/6/2024 4:50:56 PM] Preparing USB drive
[5/6/2024 4:50:56 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/6/2024 4:50:56 PM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/6/2024 4:51:08 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/6/2024 4:51:12 PM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[5/6/2024 4:51:12 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[5/6/2024 4:51:12 PM] Copying: GB5T-14G386-SC_85041.tar.gz
[5/6/2024 4:51:12 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[5/6/2024 4:51:12 PM] Copied: GB5T-14G386-SC_85041.tar.gz
[5/6/2024 4:51:12 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[5/6/2024 4:51:12 PM] Copying: 1u5t-14g386-cb.tar.gz
[5/6/2024 4:51:12 PM] Validating: 1u5t-14g386-cb.tar.gz
[5/6/2024 4:51:12 PM] Copied: 1u5t-14g386-cb.tar.gz
[5/6/2024 4:51:12 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/6/2024 4:51:12 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/6/2024 4:51:12 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/6/2024 4:51:12 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[5/6/2024 4:51:12 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/6/2024 4:51:12 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/6/2024 4:51:22 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/6/2024 4:51:25 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[5/6/2024 4:51:25 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/6/2024 4:51:25 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/6/2024 4:51:46 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/6/2024 4:51:50 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[5/6/2024 4:51:50 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/6/2024 4:51:50 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/6/2024 4:52:32 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/6/2024 4:52:38 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[5/6/2024 4:52:38 PM] Checking Existing File: 4U5T-14G421-CJF_1682462901000.TAR.GZ
[5/6/2024 4:52:38 PM] Copying: 4U5T-14G421-CJF_1682462901000.TAR.GZ
[5/6/2024 4:53:11 PM] Validating: 4U5T-14G421-CJF_1682462901000.TAR.GZ
[5/6/2024 4:53:16 PM] Copied: 4U5T-14G421-CJF_1682462901000.TAR.GZ
[5/6/2024 4:53:16 PM] Checking Existing File: 4U5T-14G421-CHF_1682462859000.TAR.GZ
[5/6/2024 4:53:16 PM] Copying: 4U5T-14G421-CHF_1682462859000.TAR.GZ
[5/6/2024 4:54:05 PM] Validating: 4U5T-14G421-CHF_1682462859000.TAR.GZ
[5/6/2024 4:54:12 PM] Copied: 4U5T-14G421-CHF_1682462859000.TAR.GZ
[5/6/2024 4:54:12 PM] Checking Existing File: 4U5T-14G421-CFF_1682462169000.TAR.GZ
[5/6/2024 4:54:12 PM] Copying: 4U5T-14G421-CFF_1682462169000.TAR.GZ
[5/6/2024 4:55:07 PM] Validating: 4U5T-14G421-CFF_1682462169000.TAR.GZ
[5/6/2024 4:55:15 PM] Copied: 4U5T-14G421-CFF_1682462169000.TAR.GZ
[5/6/2024 4:55:15 PM] Checking Existing File: 4U5T-14G421-CGF_1682462518000.TAR.GZ
[5/6/2024 4:55:15 PM] Copying: 4U5T-14G421-CGF_1682462518000.TAR.GZ
[5/6/2024 4:56:18 PM] Validating: 4U5T-14G421-CGF_1682462518000.TAR.GZ
[5/6/2024 4:56:27 PM] Copied: 4U5T-14G421-CGF_1682462518000.TAR.GZ
[5/6/2024 4:56:27 PM] Checking Existing File: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[5/6/2024 4:56:27 PM] Copying: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[5/6/2024 4:57:21 PM] Validating: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[5/6/2024 4:57:29 PM] Copied: 4U5T-14G421-CEF_1682461522000.TAR.GZ
[5/6/2024 4:57:29 PM] Checking Existing File: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[5/6/2024 4:57:29 PM] Copying: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[5/6/2024 4:58:34 PM] Validating: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[5/6/2024 4:58:42 PM] Copied: 4U5T-14G421-CDF_1682463264000.TAR.GZ
[5/6/2024 4:58:42 PM] Checking Existing File: 4U5T-14G421-CCF_1682461368000.TAR.GZ
[5/6/2024 4:58:42 PM] Copying: 4U5T-14G421-CCF_1682461368000.TAR.GZ
[5/6/2024 4:59:38 PM] Validating: 4U5T-14G421-CCF_1682461368000.TAR.GZ
[5/6/2024 4:59:44 PM] Copied: 4U5T-14G421-CCF_1682461368000.TAR.GZ
[5/6/2024 4:59:44 PM] Checking Existing File: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[5/6/2024 4:59:44 PM] Copying: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[5/6/2024 5:00:43 PM] Validating: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[5/6/2024 5:00:50 PM] Copied: 4U5T-14G421-CBF_1682461295000.TAR.GZ
[5/6/2024 5:00:50 PM] Checking Existing File: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[5/6/2024 5:00:50 PM] Copying: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[5/6/2024 5:01:39 PM] Validating: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[5/6/2024 5:01:45 PM] Copied: 4U5T-14G421-CAF_1682461100000.TAR.GZ
[5/6/2024 5:01:45 PM] Checking Existing File: 4U5T-14G424-CF_1682464057000.TAR.GZ
[5/6/2024 5:01:45 PM] Copying: 4U5T-14G424-CF_1682464057000.TAR.GZ
[5/6/2024 5:01:45 PM] Validating: 4U5T-14G424-CF_1682464057000.TAR.GZ
[5/6/2024 5:01:45 PM] Copied: 4U5T-14G424-CF_1682464057000.TAR.GZ
[5/6/2024 5:01:45 PM] Checking Existing File: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[5/6/2024 5:01:45 PM] Copying: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[5/6/2024 5:02:46 PM] Validating: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[5/6/2024 5:02:54 PM] Copied: 4U5T-14G422-CAM_1682463335000.TAR.GZ
[5/6/2024 5:02:54 PM] Checking Existing File: 4U5T-14G422-CBM_1682463581000.TAR.GZ
[5/6/2024 5:02:54 PM] Copying: 4U5T-14G422-CBM_1682463581000.TAR.GZ
[5/6/2024 5:03:32 PM] Validating: 4U5T-14G422-CBM_1682463581000.TAR.GZ
[5/6/2024 5:03:36 PM] Copied: 4U5T-14G422-CBM_1682463581000.TAR.GZ
[5/6/2024 5:03:36 PM] Checking Existing File: 4U5T-14G422-CCM_1682463747000.TAR.GZ
[5/6/2024 5:03:36 PM] Copying: 4U5T-14G422-CCM_1682463747000.TAR.GZ
[5/6/2024 5:04:05 PM] Validating: 4U5T-14G422-CCM_1682463747000.TAR.GZ
[5/6/2024 5:04:08 PM] Copied: 4U5T-14G422-CCM_1682463747000.TAR.GZ
[5/6/2024 5:04:08 PM] Generating reformat.lst
[5/6/2024 5:04:08 PM] Generating autoinstall.lst
[5/6/2024 5:04:08 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Interrogator Log
Sync_inter.xml.xml (11.0 KB)
So the APIM is just broke? Any other suggestions?
