F11 Maps not loading "Navigation Malfunction"
Hi
Driving along teh screen went blank on Sync, came back on, maps wont load with the following on screen error
“Navigation Malfunction, Navigation not functioning properly, please visit your dealer for a service”
2019 factory Sync 3. 3 months ago I did Cyan Lab update to 3.4, VBuild 222000, F11 Maps - was all working well until yesterday
Mast reset to no effect
Before I do a rebuild from here, any ideas?
Greg, todays log interrogator below
VIN: WF0NXXGCHNKL45211
Version NU5T-14G381-AA
APIM Model: 4U5T-14G371-GFA
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 11G
08/08/2023 08:13:39 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 1.0M / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.8M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 336K / 38M
/fs/sd/MAP/ = 5.6M / 3.2G
/fs/sd/MAP/ = 25M / 3.2G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 29M / 4.8G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 986M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 11G / 54G
Installed Packages
1U5T-14G421-BAJ
1U5T-14G421-BBJ
1U5T-14G421-BCJ
1U5T-14G421-BDJ
1U5T-14G421-BEJ
1U5T-14G421-BFJ
1U5T-14G421-BGJ
1U5T-14G421-BHJ
1U5T-14G421-BJJ
5U5T-14G391-AT
4U5T-14G422-BAH
4U5T-14G422-BBH
4U5T-14G422-BCH
4U5T-14G422-BDH
4U5T-14G423-AC
1U5T-14G658-AH
APIM AsBuilt
DE00: 8A6A01DA50026E444084
DE01: 554B080BC00B4890ACBCEE05
DE02: 0000010000
DE03: 00001D8002010B
DE04: 190519052653
DE05: 80
DE06: 0B0033000000005EF100005656620061
Old SYNC Version: 3
above
Syn3 Updater Version: 2.11
APIM Size: 64GB
Installed Packages
1U5T-14G421-BAJ
1U5T-14G421-BBJ
1U5T-14G421-BCJ
1U5T-14G421-BDJ
1U5T-14G421-BEJ
1U5T-14G421-BFJ
1U5T-14G421-BGJ
1U5T-14G421-BHJ
1U5T-14G421-BJJ
5U5T-14G391-AT
4U5T-14G422-BAH
4U5T-14G422-BBH
4U5T-14G422-BCH
4U5T-14G422-BDH
4U5T-14G423-AC
1U5T-14G658-AH
APIM AsBuilt
DE02: 0000010000
DE04: 190519052653
DE05: 80
Not really, that sounds like a dying APIM.
Try reformatting it once again with the latest build, no guarantees of course since it’s exhibiting a strange behavior.
This could be a conflict with the OTA update function. Reformat the APIM as suggested above and then turn off the automatic updates in Sync.
Possibly but the automatic updates have been switched off since the update I did as per advice on here
That doesn’t look like a valid version. :wink:
Oops, 22200 !
I used to own a 2013 Ford Fiesta, the Sync or whatever it was had a bad habit of freezing when playing music
So I resorted to what I used to do wit that unit
Pulled out the two fuses from box inside to toatlly cut power to Sync
Wait a few minutes
Fuses back in and Master reset
Seems to have cured it, working fine now
