Hi, I successfully updated in summer 2020 thanks to you geniuses, but I just wanted to check if I am good to go for an update to F11 Maps with no other changes based on my current build?
Old SYNC Version: 3.4.20351
New SYNC Version: 3.4.20351
No errors
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-12-06" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN></p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-EM</d2p1:Response>
</d2p1:DID>
<d2p1:Response>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</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>3a7c4848</d2p1:Response>
</d2p1:DID>
<d2p1:Response>2c49e01c</d2p1:Response>
</d2p1:DID>
<d2p1:Response>026a05da5002fc0440c2</d2p1:Response>
</d2p1:DID>
<d2p1:Response>554b0001c08a088028b80005</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010004</d2p1:Response>
</d2p1:DID>
<d2p1:Response>00001d82010000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>190819082653</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0b0533000000006428000056565f0061</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-DF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>H1BT-14G380-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>H1BT-14G371-FEC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-FB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>NW9901BG</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-DF</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>3c:a3:08:26:83:6f</d2p1:Response>
</d2p1:DID>
<d2p1:Response>3c:a3:08:26:83:70</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2022-12-06T19:00:06+00:00" RAM="1038508032" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="892K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="21M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="396K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.7M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.9G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.3G" available="25M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.6G" available="35M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="998M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="924M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="128M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="73M" available="432K"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="11G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
