desewers
(Des Ewers)
18 October 2025 15:29
1
Since upgrading from Sync 3 versions: 3.0.20204 Maps F6.1 to 3.4.23188 Maps F12 when asking for “Find an Address” I get a message back from Grace the goes something like, “That feature is not available, upgrade maps to enable that function”. I have since upgraded from F12 to F13 (2023) and then F13 (2024) but no change. Any ideas?
Old SYNC Version: 3.0.20204
File no longer there
F150Chief
(F150Chief)
18 October 2025 18:42
3
Run the Interrogator Utility and post the XML here…
desewers
(Des Ewers)
19 October 2025 10:34
4
No, not sure how to do that, sounds “final” when aplied to a PC
desewers
(Des Ewers)
19 October 2025 10:37
5
Went to try this but the “prepare drive” button is greyed out
desewers
(Des Ewers)
19 October 2025 10:41
6
OK, read how to do this but everything is lost, I have a lot of info I’d rather not trash.
desewers
(Des Ewers)
19 October 2025 14:39
7
VIN: WF0AXXWPMAHE32476
APIM Model: JL7T-14G371-FCC
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 23G
Version 3.4.23188 (NU5T-14G381-AD)
19/10/2025 15:35:29 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 976K / 1.2G
/fs/sd/MAP/ = 15M / 3.0G
/fs/sd/MAP/ = 14M / 2.4G
/fs/sd/MAP/ = 7.8M / 1.6G
/fs/sd/MAP/ = 17M / 2.4G
/fs/sd/MAP/ = 26M / 3.7G
/fs/sd/MAP/ = 312K / 41M
/fs/sd/MAP/ = 4.9M / 3.4G
/fs/sd/MAP/ = 27M / 3.4G
/fs/Nuance/ = 26M / 4.5G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 838M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 87M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 23G / 54G
Installed Packages
1U5T-14G421-BAL
1U5T-14G421-BBL
1U5T-14G421-BCL
1U5T-14G421-BDL
1U5T-14G421-BEL
1U5T-14G421-BFL
1U5T-14G421-BGL
1U5T-14G421-BHL
1U5T-14G421-BJL
5U5T-14G391-AT
4U5T-14G422-BDL
4U5T-14G423-AC
1U5T-14G658-AH
1U5T-14G424-BN
APIM AsBuilt
DE00: 0B6845DA9002BE570002
DE01: 554B01044002480000000005
DE02: 0400010000
DE03: 01001C01250001
DE04: 18061810295F
DE05: 80
DE06: 17003B0000000000FA00000430760057
F150Chief
(F150Chief)
19 October 2025 16:58
8
If you load all of the map and voice files for the NAV the problem will likely be resolved.
Des Ewers:
4U5T-14G422-BDL
Only 1 voice file loaded.
desewers
(Des Ewers)
19 October 2025 20:17
9
Thanks, not sure how I just load specific files, is the a guide?
F150Chief
(F150Chief)
20 October 2025 15:58
10
You can do it with Syn3 Updater. You will have to select the map voice files and make a usb just like you did for the maps but this is NOT using reformat, only autoinstall.
desewers
(Des Ewers)
21 October 2025 10:36
11
OK, did that, took over an hour to do the update. I did get and error message saying the install had failed, however, all the voice commands are all working so maybe it failed due to not loading maps etc. The is no XML file on the drive! Many thanks for your help.
system
(system)
Closed
23 October 2025 10:37
12
