Ford Ranger upgrade Sync 3.0 to Sync 3.4
The 2018 Ford Ranger has Sync version 3.0/18025.
Could you advise me on how to get version 3.4 installed in the vehicle?
I read that I need to install version 3.2 first and then 3.4, but I can’t seem to find version 3.2.
Thanks for the help.
Run the interrogator to verify that the hardware isnt M2020 (date on the apim and vehicle model year arent always a good way to determine this).
Coming from 3.0 this is a simple reformat install, if you dont have factory NAV use 3.4.21265.
If you have Factory NAV I’d use 3.4.23188 and the most current maps.
The vehicle, a Ranger, was manufactured in 11/2018 and sold in 01/2019.
Whenever I try to install version 3.4, I consistently get error LST-005.
The USB drive was formatted correctly (exFAT, full/slow format), followed by using CyanLabs to load Sync 3.4—yet the aforementioned error persists.
P.S. When I attempted an update via Wi-Fi, it tried to install file JR3T-14G391…
Pull the update to sync from owner.ford.com using your VIN, and install from USB.
The current build version you have listed of 3.0.18025 would lead me to believe the APIM was replaced at some point since a 2018 with Sync 3 from the factory would have a 3.0.2x build.
If that won’t install you’ve either got bad USB ports on an APIM issue
Keep in mind that the only real difference between 3.0.23219 & 3.4.23188 is a prettier interface, with what you have already stated I wouldn’t even try to use 3.4.26057 (which Ford still has as dealer only install).
Thank you for the help; I appreciate it.
