Ford SYNC 3 - Automated Method - Update to 3.4
what version number are you on?
These values in APIM AsBuilt seem most important
01-02
x*xx-xxxx-xxzz = Navigation type, 2 = 1 usb port internal nav (common)
03-01
x*xx-xxxx-xxzz = GPS Antenna location ! - 0 = roof
06-01
*xxx-xxxx-xxzz = internal gyro
this is the asbuilt i used
;Block 1
7D00101 0268 65DA 9012
7D00102 02BC 5300 02ED
;Block 2
7D00201 554B 0D06 40CD
7D00202 0208 0000 00E5
7D00203 0005 E1
;Block 3
7D00301 0000 0400 00DF
;Block 4
7D00401 0100 1A01 02FA
7D00402 0000 DD
;Block 5
7D00501 17AC 1798 2877
7D00502 BE9C
;Block 6
7D00601 805E
;Block 7
7D00701 0E03 3300 0023
7D00702 0000 1356 0049
7D00703 0004 3067 007C
7D00704 694B
I'm not sure what you mean.
Depends what version you have anything post 3.2 can be either way, note that the optional extras package is only App, no updated voice or gracenotes or logos etc.
ANZ, SA, TUR and TW (Australian, New Zealand), South America, Turkey and Taiwan
Yes :)
You can update to 20021 and then downgrade to 19101 or 19200 if you have issues
Try a master reset, if that doesn't work forscan can change the logo back
I used this file yesterday and it worked fine, I would suggest confirming the md5 matches and potentially redownload and copy the file to the usb.
Every person that has had no gps has fixed it by tweaking there Apim as-built so keep trying.
