Release notes
Last version Changes History
- Added feature
- Improved/changed feature
- Bug fixed/removed feature
2.3.41 beta, 2021-05-29 (download)
- Vehicle database update
- New configuration parameters for different modules and models
- Configuration and programming function ABS “Module initialization/relearn from Central Configuration” for:
Focus (North America) Mk3 2013-2016 model years
- Service functions PCM “DPF Static Regeneration”, “Reset the Diesel Particulate Filter Learned Values” for:
Everest 2.0 TDCi 2018 model year
F-Series Super Duty 6.7 Powerstroke 2020-2021 model years
Ranger 2.0 TDCi 2018-2020 model years - Service function PCM “Reset Crankshaft Position Sensor Adaptaion” for:
F-Series 6.7 Powerstroke 2017-2021 model years
Ranger 2.0 TDCi 2018 model year - Service functions PCM “Reset Fuel Injector Adaptation - Cylinder 1…4” for:
Everest 3.2 TDCi 2015 model year
Galaxy/S-Max 2.0 TDCi (DW10C) 2006/2010 model years
Mondeo Mk4 2.0 TDCi (DW10C) 2007/2011 model years
Ranger 3.2 TDCi 2015-2021 model years
Ranger 2.0 TDCi 2018 model year - Service functions PCM “Reset SCR inducement fault”, “Reset the Low-Pressure Fuel System Learned Values”, “Reset oil change indicator” for:
Ranger 3.2 TDCi 2015 model year
Ranger 2.0 TDCi 2018 model year - Service functions PCM “Reset SCR converter Learned Values”, “SCR System Refill Activation”, “Reset Differential Pressure Sensor Learned Values”, “Read Fuel Injector correction factors”, “Change Fuel Injector correction factors”, “Reset the Water In Fuel Warning Indicator”, “Reset the High Pressure Fuel System Learned Values”, “Reset MAF Sensor Adaptation”, “Reset EGR Valve Adaptations”, “Camshaft Position Reference Adaption Learn”, “Reset the Intake Air Throttle Valve Learned Values”, “Reset the Turbocharger Variable Vane Position Sensor Adaptation” for:
Ranger 2.0 TDCi 2018 model year - Service function CCM “Calibrate Cruise Control Sensors” for:
Escape 2020+ model year
Fiesta 2017+ model year
Kuga 2020+ model year
Lincoln Corsair 2020+ model year - Service function SASM “Steering Wheel Angle Trim”, “Steering Motor Angle Trim” for the following vehicles with adaptive steering:
Galaxy/S-Max 2015 model year
Edge 2015-2020 model years
F-Series 2017-2019 model years
Lincoln Continental 2017-2021 model years
Lincoln MKX / Nautilus 2016-2021 model years - Service function ABS “ABS Service Bleed” for:
Contour 1999-2000 model years
Cougar 1999-2002 model year
Taurus 2000-2003 model years
Mercury Mystique 1999-2000 model years
Mercury Sable 2000-2003 model years - Service function ABS “ABS Service Bleed”, “Calibrate Steering Angle Sensor”, “Calibrate Lateral Acceleration Sensor”, “Calibrate Longitudinal Sensor”, “Calibrate Pressure Sensor”, “Hydraulic Control Unit Inlet Valve Calibration”, “Hydraulic Control Unit Isolation Valve Calibration” for:
Lincoln Corsair 2020+ model year - Service functions EPB “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”, “Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
Lincoln Corsair 2020+ model year - Service functions DDM “Power Window Initialization (driver’s side)”, PDM “Power Window Initialization (passenger’s side)” (experimental!) for:
Mondeo Mk5 2015 model year
Galaxy/S-Max 2015 model year - Service functions VDM “VIN Learn”, “Ride Height Calibration” for the following models with pneumatic suspension:
Mustang GT350R 5.2 TiVCT 2015-2017 model years
Mustang all modifications 2018-2020 model years - GUI feature: displaying progress of the adapter’s firmware update process
- GUI feature: displaying voltage that was read from the adapter with low refresh rate at the bottom right corner
- Support for Vgate vLinker FS
- improved support for Vgate vLinker FD
- improved support for 2021MY models (S-Max, Bronco Sport, some Mazda 3)
- improvement and optimization of adapter’s firmware update procedure
- bug in FTDI write timeout (might cause failure of OBDLink EX adapter firmware update on low baud rates)
