2.3.43 release, 2021-09-28 (download)
Release notes:
Added feature
- New configuration parameters for different modules and models
- Service functions PCM “DPF Static Regeneration”, “Reset the Diesel Particulate Filter Learned Values” for:
C-Max 2.0 TDCi 2015 model year - Service functions IPMA “Local Interconnect Network New Module Calibration” for:
F-150 2021 model year - Service function IPMA “Lane Departure Warning System Camera calibration” for:
Bronco 2021 model year
F-150 2021 model year - Test “OCS System Zero Weight Test” and service function “OCS System Reset” for:
Edge 2007-2009 model years
Explorer 2006-2010 model years
Flex 2009 model year
Fusion 2006-2008 model years
Lincoln MKS 2009 model year
Lincoln MKX 2007-2009 model years
Lincoln MKZ 2006-2008 model years
Mercury Milan 2006-2010 model years
Mercury Mountaineer 2006-2010 model years
Mercury Zephyr 2006-2008 model years - Service procedure HCM “Headlamp Alignment And Calibration” for:
F150 2021 model year - Service function HVAC “Actuators Calibration” for:
Bronco 2021 model year - Service function HVAC “Reset the Outside Air Temperature Sensor Learned Values” for:
Ecosport 2018 model year
Escape/Kuga 2020 model year
Explorer Mk6 2020 model year
Fiesta 2017 model year
Focus Mk4 2019 model year
Lincoln Corsair 2020 model year
Lincoln Aviator 2020 model year
Improved/changed feature
- Improved support for 2022MY F-Series: proper recognition of two different versions of network configuration
Bug fixed/removed feature
- bug in PATS Module Initialization function for Focus Mk2 2003-2007 with RFA (procedure didn’t allow to pair IPC with PCM)
- incorrect algorithm of reading freeze frame that didn’t work properly on some ECUs
- rare bug of incorrect module recognition
