2.3.44 release, 2021-11-25
Download
Release notes:
Added feature
- Vehicle database update
- New configuration parameters for different modules and models
- Configuration and Programming function “Transmission Characterization Update” for:
Escape 2.0 Ecoboost 2020 model year
Everest 2018-2020 model years
Ranger 2018-2021 model years - Configuration and programming function PCM “Module initialization/relearn from Central Configuration” for:
Escape 2.0 Ecoboost 2020 model year - Service functions PCM “Clear Transmission Adaptive Tables” for:
Escape 2.0 Ecoboost 2020 model year - Service functions PCM “DPF Static Regeneration”, “Reset the Diesel Particulate Filter Learned Values”, “Reset Differential Pressure Sensor Learned Values”, “Read Fuel Injector correction factors”, “Change Fuel Injector correction factors”, “Reset oil change indicator”, “Reset the Water In Fuel Warning Indicator”, “Reset MAF Sensor Adaptation”, “Reset the High Pressure Fuel System Learned Values”, “Reset the Low Pressure Fuel System Learned Values”, “Reset Crankshaft Position Sensor Adaptation” for:
Ecosport (EU) 1.5 TDCi StgVI 2018 model year - Service functions PCM “Reset Differential Pressure Sensor Learned Values”, “Reset the High Pressure Fuel System Learned Values”, “Reset pilot injection quantity learned values”, “Reset pilot injection quantity learned values - Cylinder 1…4” for:
Edge 2.0 TDCi 2016+ model year - Service functions TCM “Shift Fork System Learn” and “Clutch System Learn” for Powershift DCT450 for:
Transit Connect (EU) 1.5 TDCi Stg VI 2014 model year - Service function ABS “Calibrate AdvanceTrac/IVD” for:
Expedition 2015-2017 model years
F-150 2009-2014 model years
Flex 2009-2012 model years
Ranger 2010-2011 model years
Lincoln MKT 2009-2012 model years
Lincoln Navigator 2015-2017 model years
Mazda BT-50 2010-2011 model years - Service functions DDM “Power Window Initialization (driver’s side)”, PDM “Power Window Initialization (passenger’s side)” for:
C-Max (EU) 2011 model year
Focus Mk3 (EU) 2011 model year
Transit Connect (EU) 2011 model year - Service functions for ABS/ESP module: “Calibrate Lateral Acceleration Sensor”, “Calibrate Longitudinal Sensor”, “Calibrate Pressure Sensor” , “Calibrate Yaw Rate Sensor”,“Calibrate Roll Rate Sensor” for:
Ecosport 2018 model year - Service function CCM “Calibrate Cruise Control Sensors” for:
F150 2021-2022 model years
F-Series 2020-2022 model years - Service procedure HCM “Headlamp Alignment And Calibration” for:
Focus Mk4 2019 model year
Kuga 2017 model year (equipped with HCM module)
Kuga 2020 model year
Lincoln Aviator 2020 model year
Lincoln Corsair 2020 model year - Configuration and Programming function IPC “Odometer write” (can only increase mileage!) for:
Transit Custom 2019 model year - TCM module support for Mondeo Mk4/S-Max 2019 model year
- vLinker FS automated firmware update (up to v2.2.82)
- New application settings for CSV export: column delimiter (semi-colon or comma) and timestamp type (relative or absolute)
Improved/changed feature
- fixes and improvements in communication procedure with vLinker FS
- improved loading factory AB file (error processing)
- Improved support for 2021-2022MY models (Mach-E, F-Series)
Bug fixed/removed feature
- bug entering PATS programming in Mazda 2 1.4 MZI 2002
- incorrect recognition module calibration level on some models (bug appeared in 2.3.43)
- inability to load Central Configuration on some models (bug appeared in 2.3.43)
- inabiltiy to gain security access for Output Control functionality for some models
