FORScan 2.3.46 Released 2022-02-07
2.3.46 release, 2022-02-07 (download)
Release notes:
Added feature
- New configuration parameters for different modules and models
- Configuration and Programming function IPC “Odometer write” (can only increase mileage!) for:
F-150 2021 model year - Configuration and Programming function “Transmission Characterization Update” for:
Bronco Sport Ecoboost 2021-2022 model years - Service functions PCM “Clear Transmission Adaptive Tables” for:
Bronco Sport Ecoboost 2021-2022 model years - Service function PCM “Low Pressure Fuel System Prime” for:
Edge 2.0 TDCi 2016+ model year - Service function PCM “Misfire Monitor Neutral Profile Correction”, “Reset all adaptations” for
Mondeo Mk5 2.0 Ecoboost Stg V 2015+ model year - Service function RCM “Crash Flag Reset” for Focus Mk3.5 RS
- Service function CCM “Calibrate Cruise Control Sensors” for:
Focus Mk3 2011 model year
Galaxy/S-Max 2006/2010 model years
Mondeo Mk4 2007/2011 model years
Transit 2012/2014/2017 model years - Service functions PSCM “Enable Pull Drift Compensation”, “Disable Pull Drift Compensation” for:
C-Max 2011 model year
Focus Mk3/Mk3.5 2011/2015 model year - Support Mazda Japan VIN (10 characters) in the “Load factory AB” sub-function of the Module Configuration (As Built format) function
- HSWM support for F-150 (P415) 2012-2014 model years
Improved/changed feature
- improved support for 2021MY (Bronco Sport) and 2022MY models (Bronco Sport, Edge, Escape, Mach-E, Ranger, Lincoln Corsair)
- fix in Service function PCM “Reset oil change indicator” for Ranger 2.0 TDCi 2018+ model years: if PCM doesn’t support this service function and requires manual reset, FORScan will provide relevant information on how to complete the procedure instead of displaying error message
Bug fixed/removed feature
- incorrect VID block checksum calculation for F-Series (P473 Platform) 6.7 Powerstroke 2011-2016 model years
- incrorrect “negative” timestamps in some freeze frames
