FORScan 2.3.47 Released 2022-04-19
2.3.47 release, 2022-04-19 (download)
Release notes:
Added feature
Vehicle database update
New configuration parameters for different modules and models
Service functions ABS/ESP “Calibrate Steering Angle Sensor”, “Calibrate Lateral Acceleration Sensor”, “Calibrate Longitudinal Sensor”, “Calibrate Pressure Sensor”, “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”, “Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
Explorer 2020+ model years
Lincoln Aviator 2020+ model years -
Service function “OCS System Reset” for:
Mazda 3 2004-2009 model years
Mazda 5 2006-2010 model years
Mazda 6 2005-2008 model years
Mazda CX-7 (NA) 2007-2010 model years
Mazda CX-9 (NA) 2007-2011 model years
Mazda MPV 3.0 2004-2006 model years
Mazda MX-5 (NA) 2006-2010 model years
Mazda RX-8 (NA) 2006-2010 model years -
Service procedure HCM “Headlamp Alignment And Calibration” for:
Edge 2019-2020 model years
Mustang 2018 model year
Taurus 2016/2019 model years
Lincoln Continental 2017-2018 model years -
Service function FCIM"Reset the Outside Air Temperature Sensor Learned Values" for:
Everest 2015-2020 model year
Ranger 2015-2022 model year -
Service functions PSCM “Enable Pull Drift Compensation”, “Disable Pull Drift Compensation” for:
C-Max Mk2 2015 model year
Escape 2013-2019 model years
Kuga 2013-2019 model years -
Support SYNC4 for:
Maverick 2022 model year
Lincoln MKZ 2015-2020 model years -
Tests “KOEO Injector Electrical Self Test” (so-called “buzz test”) for:
Edge 2.0 TDCi 2019-2020 model years
Everest 2.2/3.2 TDCi 2015 model year
Everest 2.0 TDCi 2018 model year
F-150 3.0 Powerstroke 2018-2022 model years
Focus Mk4 2.0 TDCi 2019 model year
F-Series 6.7 Powerstroke 2011-2022 model years
Ranger 2.2/3.2 TDCi 2015 model year
Ranger 2.0 TDCi 2018 model year
Transit (North America) 3.2 TDCi 2015-2020 model years
Transit (EU, NA) 2.0 TDCi 2019-2020 model years
Improved/changed feature
- improvement in license key file loading procedure: FORScan will recognize if Hardware ID in the license key file doesn’t match to the Hardware ID detected for this PC
- improved support for 2021-2022MY (Bronco, Bronco Sport, E-Series, Expedition, Explorer, F-150, Maverick, S-Max, Transit North America, Transit Connnect MCA)
- improvement in CAN commnication procedure
- improvement in “PATS Programming” for Falcon FG Mk1: now, even if the PCM is partially immobilized, FORScan will be able to gain security access and finish the module initialization (dealership scanner has a bug and cannot do this trick!)
Bug fixed/removed feature
- bug in J2534 implementation that prevented connection to some new ECU (SODCMC, SODCMD, BCMC, OBCC etc)
- non-working “ISO15675=In application” option for vLinker FS (requires vLinker FS firmware update to v2.2.86 that is included into this release)
- incorrect work of service functions PSCM “Reset Pull Drift Compensation”, “Straight Ahead Adaption Angle Reset” for Focus Mk3/3.5, C-Max, Escape 2013+MY, Kuga 2013+MY
- bug in displaying NOX Effectiveness OBD Mode6 test results
- bug starting service function IPMA “Lane Departure Warning System Camera calibration” for:
F150 2021-2022 model years
