FORScan 2.3.48 Released 2022-06-22
2.3.48 release, 2022-06-22 (download)
Release notes:
June 22, 2022 - FORScan for Windows version 2.3.48 is released
Vehicle database update, improved support for 2022 MY model, some new functions, fixes and improvements.
Last version Changes History
Added feature
New configuration parameters for different modules and models
Configuration and Programming function “Transmission Characterization Update” (see note below) for:
Edge 2007-2011 model years
Escape/Mazda Tribute/Mercury Mariner (except HEV) 2009-2011 model years
F-150 2010-2011 model years
F-Series (except 6.8 3V) 2011 model year
Flex 2009-2011 model years
Fusion/Mercury Milan (except HEV, 3.5L 4V, 2.5L I4) 2010-2011 model years
Mustang 3.7/5.0 TiVCT 2011 model year
Taurus 2008-2011 model years
Taurus X 3.5L 4V 2008-2009 model years
Lincoln MKS 2009-2011 model years
Lincoln MKT 2010-2011 model years
Lincoln MKX 2007-2011 model years
Mercury Sable X 3.5L 4V 2008-2009 model years
Note: many of these PCMs have Transmission ID block integrated into PCM firmware and require FORScan v2.4 with Module Firmware Update function (MFU) -
Service functions PCM “DPF Static Regeneration”, “Reset the Diesel Particulate Filter Learned Values”, “Reset Differential Pressure Sensor Learned Values”, “Reset SCR converter learned values”, “SCR System Refill Activation”, “Empty the SCR system”, “Reset pilot injection quantity learned values”, “Reset pilot injection quantity learned values - Cylinder 1…6”, “Reset Nitrogen Oxide Sensor (NOX) #1 Adaptations”, “Reset Oxidation Catalyst Adaptation”, “Reset Crankshaft Position Sensor Adaptation”, “Reset EGR Valve Adaptations”, “Reset the Intake Air Throttle Valve Learned Values”, “Reset the Water In Fuel Warning Indicator”, “Reset MAF Sensor Adaptation” for:
F-150 3.0 Diesel 2021+ model years -
Service functions PCM “Read Fuel Injector correction factors”, “Change Fuel Injector correction factors” for:
F-150 3.0 Diesel 2018-2022 model years -
Service function “Fuel Injector Pilot Correction Learn” for:
Edge 2.0 TDCI 2016+ model years
Galaxy/S-Max 2015/2021 model years
Mondeo Mk5 2.0 TDCi StgV/StgVI 2015 model year -
Service functions ABS/ESP “Calibrate Steering Angle Sensor”, “Calibrate Lateral Acceleration Sensor”, “Calibrate Longitudinal Sensor”, “Calibrate Pressure Sensor”, “Calibrate Tandem Master Cylinder (TMC) Travel Sensor”, “Apply and Release Calibration (Assembly Test)”, “Enter Electric Parking Brake Maintenance Mode”, “Exit Electric Parking Brake Maintenance Mode”, “Apply Electrical Parking Brake”, “Release Electrical Parking Brake”, “Apply left EPB actuator”, “Release left EPB actuator”, “Apply right EPB actuator”, “Release right EPB actuator” for:
Maverick 2022 model year -
Service function ABS “ABS Service Bleed” for:
Transit (North America) 2020+ model year -
Service function CCM “Calibrate Cruise Control Sensors” for:
Puma 2020+ model year -
Service function IPMA “Lane Departure Warning System Camera calibration” for:
Service functions VDM “On-Board Scales - Vehicle Payload Update”, “On-Board Scales - Height Sensor Calibration”, “On-Board Scales - Spring Calibration”, “Ride Height Calibration” for:
F-150 2021 model year -
Tests "KOER “On Demand Self Test”, “KOEO Injector Electrical Self Test” (so-called “buzz test”) for:
Reworking the “foolproof” function to avoid damaging BCM due to irreversible change (ESCL configuration parameter): now the “foolproof” works for all known BCM versions and models
Improved/changed feature
- fixes and improvements in service function CCM “Calibrate Cruise Control Sensors”
- improved support for 2022MY models
- other small fixes and improvements
Bug fixed/removed feature
- bug in RCM Configuration and Programming function “Module initialization/relearn from Central Configuration” for Fiesta EU 2013-2016 model years (access denied error)
- service function “Enable/Disable Passenger Airbag Deactivation switch” Fiesta EU 2013-2016 model years (not really supported by RCM)
- bug in ABS Service Bleed service function for 1998 Explorer and several other 1997-2000MY models
- incorrect work of PCM service function “Reset EGR Valve Adaptations”, “Reset the Turbocharger Variable Vane Position Sensor Adaptation”, “Reset the Intake Air Throttle Valve Learned Values” for Mondeo Mk5 2.0 TDCi StgVI 2015 model year
- Incorrect work with Mazda Japan frame codes in configuration and programming functions
