FORScan 2.3.49 Released 2022-10-19
2.3.49 release, 2022-10-19 (download)
Release notes:
October 19, 2022 - FORScan for Windows version 2.3.49 is released
Vehicle database update, improved support for 2022 MY model, multiple new functions, fixes and improvements.
Last version Changes History
Added feature
- Vehicle database update
- New configuration parameters for different modules and models
- Configuration and Programming function PCM “Transmission Characterization Update” for:
Mondeo Mk5 1.5/2.0/2.5 Ecoboost/IVCT with automated 6F tranmission - Configuration and Programming functions BCM “RF Keypad Learning by Serial Number”, “RF Keypad Learning by 48-char Code” for:
Edge 2015-2020 model years
Explorer 2016-2019 model years
F-150 2015-2020 model years
F-Series 2017-2020 model years
Fusion 2013-2020 model years
Galaxy/S-Max 2015 model year
Mondeo Mk5 2015 model year
Mondeo (China) 2017/2019 model years - Service functions PCM/DCU “Reset SCR converter learned values”, “Reset Oxidation Catalyst Adaptation”, “Reset SCR inducement fault”, “Reset SCR adaptations after Reductant Injector repair/replacement with pressure line emptied”, “Reset SCR adaptations after Reductant Injector repair/replacement without pressure line emptied”, “Reset SCR adaptations after Reductant Supply Pump repair/replacement”, “Reset SCR adaptations after Reductant Tank repair/replacement”, “Reset SCR adaptations after Reductant Line repair/replacement”, “Reset SCR adaptations after Reductant Refill”, “Reset SCR adaptations after Reductant replacement” for the following diesel models with SCR/DCU system:
Focus Mk4 1.5 TDCi 2019 model year
Transit Connect (V408MCA) 1.5 TDCi 2019-2022 model years - Service functions PCM “Clear Transmission Adaptive Tables” for:
Mondeo Mk5 1.5/2.0/2.5 Ecoboost/IVCT with automated 6F tranmission - Service function ABS “IVD Initialization” for Escape 2005-2007
- Service procedure RFA “Remote Keyless Entry and Start Programming” (models with start button) for:
Mazda 3/Axela (All markets) 2006-2009 model years
Mazda 6/Atenza (All markets) 2007-2012 model year - Service functions ABS/ESP “Calibrate Longitudinal Sensor” for:
F-150 2021-2022 model years - Service function CCM “Calibrate Cruise Control Sensors” for:
Bronco 2021+ model years
Bronco Sport 2021+ model years - Service function RCM “Crash Flag Reset” for Ford Ka 2015 model year
- Service procedures IPMA “Rear Camera Calibration”, “Pro Trailer Backup Assist Camera Calibration”, “360 degree View Camera Calibration” for:
Improved/changed feature
- improved support for 2022MY models (F-150 BEV, new Ranger P703, Everest U704, Lincoln Navigator and others)
- improved loading vehicle profile in case of no connection to PCM: VIN is taken from the profile that will let user load As Built Data by VIN
- improved PCM Vehicle ID block for vehicles that store VID block in As Built data: procedure will now reset ECU after writing the VID block to ECU
- improved support of Ka/Figo 2018 model years (models without MS-CAN)
- improved support of last gen J2534 adapters
- fixes and improvements in the Output Control function: added some Output Control PIDs that were missing (for example TURBO_WGATE on P473 6.7 Powerstroke)
- fixes and improvements to the test “Mode 6 - Test Results for Specific Monitored Systems”: added support for some Mazda tests and new units/converters
- fixes and improvements in the PCM “Clearing Misfire Monitor Profile Correction Data” service function
- fixes and improvements in the Module Initialization subfunction of “PATS Programming” function for some of vehicles with IAK:
Edge 2011-2014 model years
Expedition 2015-2017 model years
Explorer 3.5 TiVCT 2011 model year
Explorer 2012-2015 model years
Flex 2013-2018 model years
Taurus 2013-2017 model years
Lincoln MKS 2013-2016 model years
Lincoln MKT 2013-2017 model years
Lincoln MKX 2011-2015 model years
Lincoln Navigator 2015-2017 model years
Bug fixed/removed feature
- bug: incorrect work of the service function “IVD Initialization” for Escape 2.3 HEV 2008
- bug: cannot access the Lincoln TownCar 2008 RCM As Built Data
- bug: disappeared ACM Module Calibration function for Falcon 2003-2014
- bug: DTC codes don’t appear in the DTC tab of the On Demand Self-Test function (affected all modules, Windows version only)
- bug in Output Control function: unable to get security access in some new cars
