FORScan 2.3.58 Released 2024-01-02
2.3.58 release, 2024-01-02 (download)
Last Version Changes History
Added feature
  • Vehicle database update
  • New configuration parameters for different modules and models
  • Configuration and Programming function PCM Module Configuration for Kuga Mk1 DW10C
  • Missing diesel PCM service functions for:* Kuga 1.5 TDCi 2020+ model year
    Transit /Custom (EU) 2.0 TDCi 2019 model year
  • Service functions PCM/DCU “Reset Oxidation Catalyst Adaptation”, “Reset SCR adaptations after Reductant Injector repair/replacement with pressure line emptied”, “Reset SCR adaptations after Reductant Injector repair/replacement without pressure line emptied”, “Reset SCR adaptations after Reductant Supply Pump repair/replacement”, “Reset SCR adaptations after Reductant Tank repair/replacement”, “Reset SCR adaptations after Reductant Line repair/replacement” for the following diesel models with SCR/DCU system:
    Galaxy/S-Max 2.0 TDCi StgVI 2015 model year
    Everest U375 2.0 TDCi 2018-2022 model years
    Everest U704 2.0 TDCi 2023 model year
    Mondeo 2.0 TDCi StgVI 2015 model year
    Ranger P375 2.0 TDCi 2018-2022 model years
    Ranger P703 2.0 TDCi 2023 model year
  • Service function TCM “Learn Clutch Touch Point” for:
    Fiesta/Fusion/Ikon 1.4 Duratec/TDCi (ASM transmission) 2002-2006 model years
  • Service function CCM “Calibrate Cruise Control Sensors” for:
    Transit V363 (North America) 2020-2023 model years
  • Service function VDM “Ride Height Calibration” for the following models with pneumatic suspension:
    Expedition 2018-2023 model year
    Mustang 2021-2023 model year
  • Service functions VDM “VIN Learn”, “Suspension Temperature Calibration” for the following models with pneumatic suspension:
  • Sub-function “Show distributed PATS scheme” of the “PATS Programming” function for some models.
Bug fixed/removed feature
  • bug: PATS Programming → Module initialization false initialization error message on some models even if the function has completed successfully
  • bug: disappeared service function RFA “Remote Keyless Entry and Start Programming” for many Mazda models
  • bug: incorrect work of some PATS programming functions (bug appeared in 2.3.57)
  • bug: incorrect work of RCM “Module reset/configuration” function for Focus Mk3
  • bug: incorrect work of some PCM service functions on SID-210 ECU (bug appeared in 2.3.57)
