GV6T-14C097-AA.VBF File Request
Hello,
I’ve searched around and have seen reference to the GV6T-14C097-AA.VBF file I need but no clickable links. Can I please have this file?
Thank you.
Does not seem to be in Ford’s database any longer.
FJDSSupport - FordServiceInfo.Com
I’m trying to disable my auto start/stop and thats the file that my FordScan is saying it needs. I’ll also be contacting them but I might as well ask it here too. Is there someplace else thatI should be looking for this file if its not in Fords database?
Good luck getting Ford to help you. @F150Chief might have the file.
@tfloydlex That is just the bootloader file, not a startegy file which would contain the info you need to program. There will be the bootloader and 2 other files needed, if indeed this would actually work. Could you reference the source of the information that a firmware change could disable auto start/stop…
