Thank you @F150Chief & @SaNdMaN.
The Update completed & Sync3 is working again. The above worked as stated.
Apricate you both.
FoxTalbott
Apricate you both.
FoxTalbott
Awesome. What fixed it?, recreating the USB with Syn3Updater?. If so that would confirm there was something wrong with it, even though not sure whatâŚ
Any way, enjoy it
It was your recommendation, (âAdvanced Optionâ: Install Mode = reformat & Select Packages APPS only screen grabs above). After running that, I was then able to upgrade to v3.4.21194.
@F150Chief was correct and looks like the APIM was full. This was my fault by rushing after updating the other 2017 SUV that had Nav. Did not realize Sync3 updater defaulted to Navigation Yes until I looked at the log setting. By that time it was too late.
Best Regards
Ok, good to know!, thanks for clarifying.
Btw, what Syn3Updater did was the same as what f150chief said, but automated.
So bottom line, the first USB you created had an issue.
Glad it worked, enjoy your system now.
