How do I update my 3.4 SYNC update to Cyanlabs so it is on record?
Error Code: PKG_ERR04
Installation Failed
Download file again and retry to install.
If error persists, please note the code and contact xxx-xxx-xxxx
I have a 2018 Ford F-150 Platinum. I just updated my SYNC from Build 23219 SYNC Version 3.0.23219 to Build 26057 a SYNC version from 2020 (I did not not pick the 2025 version because it was colored Red and thought I could/should not do so). I just realized I can and should have updated to the latest version which is from 2025. My system is still showing my SYNC is Version 3.0.23219 but it is not…it is the 2020 version of 3.4.
I am not sure of my new SYNC version, but this is what the screen in my F-150 says:
SYNC Version: 3.4
Build: 26057
Gracenote Version: 1.1.1.2323 (NA-0020)
Navigation Maps Version: NA 2 20
SYNC Serial Number (ESN): VW97051C
How can I go about reporting my updated version on here so I can then upgrade to the newer 2025 version correctly without getting an error? I have already wiped my USB clean but again, what can I do to report my newer version so I can properly update to the 2025 version with no error?
Old SYNC Version: 3.0.23219
New SYNC Version: 3.4.20220
I erased my USB and can not go back and check. I will download it again and retry so I can report the error code.
First of all run the Interrogator Utility in the Syn3 Updater to determine if your APIM is MY20+ or not. Just because it’s in a 2018 truck does not mean it hasn’t been replaced.
If it is not a MY20+ unit, use the Syn3 Updater to reformat the APIM and install the latest Sync 3 version along with NA 2.25 maps.
