I would like to learn about the issues and risks associated with upgrading SYNC 3 from version 2.0 to version 3.4.
My car is a Focus with a 1.5T four-cylinder engine, manufactured in December 2016. The current infotainment system is SYCN 3, version 2.0. I’d like to use Syn3 Updater to upgrade my infotainment system. I’m not sure what precautions to take or what risks are involved in this process. Please help me check if my current version supports the upgrade. I’m very concerned about potential issues. Thank very much for your help and response.
SYNC Region: CN
Old SYNC Version: 2.0.16074
New SYNC Version: 3.4.26057
https://cyanlabs.net/fhub/sync3/syn3-updater-log/?uuid=1f1d7317-980e-61be-870c-260e79c01f54
Personally I’d try to get it to 2.2.17011 first. HN1T-14G381-SA - SYNC 3 APIM Software (IVSU) Database - CyanLabs
  1. to use CP or AA you’ll need to replace the USB module (getting to 2.2.17011 is a pre-req to do this in 3.0.x) HN1T-14G381-SA - SYNC 3 APIM Software (IVSU) Database - CyanLabs after that you can go to the highest build Ford offers for your VIN on owner.ford.com and have working CP/AA.
  2. if you go to 3.4 you’ll still need to replace the USB media hub or you’ll get warnings for unsupported hardware if you don’t.
  3. Since you have a non-NAV APIM the highest build you would want to go to on 3.4 is .21265 as higher builds have some compatibility issues with non-NAV non 3.4 native APIMs
  4. You have a chance of having a screen flicker issue on 3.4, there’s not a mod to fix this
  5. Once you go to 3.4 you can’t go back to 3.0 without replacing the APIM
