Initial configuration not complete APIM
Hi guys, I have a 2020 Ford Fusion 1.5L engine, I upgraded the APIM module for some reason and now I get this error (Initial configuration not complete) and even when I go back to any version the same thing and the picture shows that
If you do a search you will find that this has to do with AB settings. It’s an easy fix with Forscan. It will not effect the operation of the APIM.
It’s fixed by re-writing all the asbuilt to the unit usually
https://www.motorcraftservice.com/AsBuilt
https://forscan.org/download.html
Update: Today I typed 0000 BLOCK 8 & 9 As-BUILT as explained to me by one of the group members and I encountered a second code which is 2101 as shown in the picture which is a mismatch and then I returned to the 5U5T-14G371-BKH version with reloading As-BUILT and things returned to normal and the compass and maps returned to work, thanks to those who helped me
