Interrogator issue
I ran the interrogator tool but get an error message from Syn3 updater about the xml file and potential use of overlays. The message advises me to request support here.
Old SYNC Version: 2.2.16280
New SYNC Version: 3.4.26057
The XML file you have selected does not contain the expected output.
Syn3 updater has determined you are on 2.2.16280 and may be using overlays.
Syn3 is unable to determine the configuration of your APIM
Please request assistance on our forum at …
VIN: WF0FXXWPCFHB39163
APIM Model: HB5T-14G371-FCA
APIM Type: Non-Navigation
APIM Size: 0GB
APIM Free Space: Unknown
Version 2.2.16280 (HN1T-14G381-LG)
10/23/2026 14:14:47 +00:00
Partition Type = Free / Total
/dev/hd0t180 = 115781600 / 21105364992
/dev/hd0t181 = 2097120 / 630440960
/dev/hd0t177 = 2097152 / 136776704
Installed Packages
HN1T-14G423-AA
HB5T-14G422-BC
HB5T-14G424-BD
HN1T-14G391-AF
HB5T-14G421-BD
APIM AsBuilt
DE00: 086A04921002BC0206C2
DE01: 42450106C00A488000000000
DE02: 0203010000
DE03: 01001D00240102
DE04: 1AC21AA42BD0
DE05: 80
DE06: 07003300000000171C000056566C006A
Which you haven’t…
What’s the end goal?, you just put out a statement, nothing else.
Install 2.2.17011 HN1T-14G381-SA - SYNC 3 APIM Software (IVSU) Database - CyanLabs
Then try again.
The end goal is to upgrade to latest sync (3.4) to hopefully fix a very slow user interface. The step I reached was to run the interrogator to confirm if I can do that since I’m not sure if the unit was ever swapped or refurbished. Here I ran into the problem as posted with syn3 updater recommending to request support on this community.
I have not yet tried to actually Install 3.4.
Can I just install the mentioned 2.2 update even with this issue I have with the interrogator? Or should I first try 3.4?
Also from the (partial) xml log it seems like I have a unit without Navigation. Do I understand that correctly and should I change the configuration for Building the updater file?
That doesn’t match with my own experience. My unit does have navigation as also shown in the “about” screen so I assume I should select navigation “yes”. See also the picture below. Last line says navigation maps version. Please confirm or help me understand.
Take it to 2.2.17011 first then try the build for your vehicle VIN on owner.ford.com .
If you can’t get it to the last Ford supported build for the vehicle there’s a good chance of the APIM not taking 3.4.x and leaving you with an even worse problem.
Going to 3.4 is a one way street and it may actually make things worse depending on the age of the APIM.
Thanks for the advice!
I used the latest available build on (Dutch) ford website for my vin (3.0).
It took roughly 30 minutes to complete. AAwireless works now and unit seems more responsive.
I’ll try this for a few weeks before deciding if I want to move to 3.4.
