I am new and just downloaded 3.4.21265, but says EU Voice. Can someone explain, I am located in the United States which update do I choose?
Sync 3.4.21265 application is worldwide application.
If you downloaded a package that says EU Voice, then you downloaded the wrong installation 'package".
Did you use the Syn3 Updater or another method?
Thank you for replying, in the car configuration I setting I having the following selected,
- 3.0.20204
- United States, Canada & Mexico
- Release branch: stable
Current Configuration:
- Version: Sync 3.4.21265
- Map version 2.20 (2020) - NA
I am confused about this message,
NOTE: ONLY EU VOICE IS NEW, IF OTHER REGIONS NO NEED TO UPDATE VOICE FROM 21194, OTHER REGIONS WILL LIKELY FOLLOW
That message will not apply to you in NA. The voice files for the newest Sync app (3.4.21265) have not been released by Ford except for the EU file. When they do eventually release, you can update the voice file only without issue.
If you have any issues with the upgrade post here and we will help.
