Keyless entry issue after upgrading to 3.4.26057
Hi,
My Sync3 unit was updated to 3.4.26057 with reformat option due to black screen problem at almost every car start. After the update the device is workign fine, however there is a new issue.
After loking the doors keyless entry is not working in the first 30-60 minutes. The door handle sensors seem blocked. After this period the keyless entry operates fine and I can open the doors without pushing the open button on the remote.
This is a Europe car modell with 32GB APIM retrofitted. Had been working fine for a couple of years. Illumitaion gateway is CGEA 1.3. I tried to set the APIM As-Built 7D0-06-01: to x1xx-xx Ithas some effect but did not resolve the issue.
Any sugesstion how to resolve my issue?
Old SYNC Version: 3.4.23088
New SYNC Version: 3.4.26057
Nope
Not available
3.4.23088 was in the list of builds with the RWDATA bug which more than likely caused your black screen problem.
You didn’t give the make/model/year of the vehicle, I would downgrade to 3.4.23188 or 3.4.21265, neither of these requires a reformat and you only need the app plus a master reset after doing the downgrade.
Thanks for your valuable response. The vehicle is a 2016 Ford Mondeo built with Sync2 originally.
Just for my curiosity, is this keyless entry issue known as bug in 3.4.26057, or why do you recommend the downgrade?
  1. 3.4.26057 is still a dealer only install, folks still can’t download it from owner.ford.com , the link gives 3.4.23188
  2. Ford doesn’t do regression testing on Sync builds on non-supported platforms, so testing is done on vehicles that came from the factory with 3.2 or higher.
  3. 3.4.21265 as a build was pretty much clean across everything and didn’t have the RWDATA partition bug, 3.4.23188 was the first build that remediated that bug.
I have seen 3.4.26057 cause an issue on a 2016 Fusion Ti HEV, the car lost the heated wheel activation on remote start (it could still be turned on manually). That car was a MFT/Sync2 upgrade to 3.4.x with an L series APIM running -EK firmware, the guy had turned off the HEV battery use screen that comes with the HEV and put the seat buttons and heated wheel buttons on the home screen.
The 2016 Fusion could have odd issues with a MFT to 3.4 upgrade mod since some of the firmware in the various modules was a one off for that year only, with those it was usually necessary to get a used (not new) GWM from a 2017. This pre-dated Forscan 2.4.x which would allow you to flash modules outside of model year/platform.
