Hi Guys, I was having such a hard time updating my sync for 3.4.2165, but after a few searchs here is what i was able to to:
Downgrade to 3.3, reformat, and install 3.4.2165 package. During this process I was getting MEM erros, and decided to install only the system and voice package for testing. it was successful.
Now, i’m trying to install latest gracenotes but Im still having MEM errors, even with my diagnostics saying there is 1.1 GB available.
Navigation Variant: No
Old SYNC Version: 3.3
New SYNC Version: 3.4.2165
MEM ERROR 3
I followed this exact tutorial. Step by step. When i downgrade to 3.3.19052 i wasnt able to install the complete packages, (system + voice + gracenotes), so I installed only system + voice. Is there any chance that the files are so big that they wont fit in 8 gb at all?
You are not following the tutorial then.
The tutorial says downgrade first, then check available free storage. If under 1.5gb, you need to continue removing stuff, and according to your message you tried to perform the upgrade at that point.
Re read the tutorial and follow it, step by step.
There are more things you can remove.
Or maybe I’m not following you.
So the question is: were you able to reformat with all the packages?.
I remove gracenotes and changed the language pack to the smaller one before downgrading, in order to try to update directly. Since i wasnt able to update, i downgraded to 3.3.19052 and tried reformating with all the packages, without success. at the end i’m in 3.4 .21265 without gracenotes.
Do you think I should try again?
downgrade, replace voice package and force reformat 3.4 with all the packages?
You followed the directions and you are where you are supposed to be. With the voice and Gracenotes packages that include portuguese BR, these are larger files. You do not have the available space with these files to install Gracenotes.
If you were to use smaller non-portuguese BR files, then yes it is possible to fit GN on the unit with Sync 3.4. With Sync 3.3, you could use these files because the Sync app is half the size of 3.4.
It may work with those files but there would be very little storage left to run the APIM. You would not have enough free space to upgrade in the future.
