Same prob as before, try to upgrade to ver. 22251 from 22200 and get mem error 3. I have 2.3G of space, I even ditched the DAB and Gracenotes but still it wouldn’t install.
I’m not reformatting and re-installing all the maps again.
I see you are putting EU maps on a 32GB APIM. Are you using a cut down map installation? Can you post the installation files?
As per the first post this is not specific to this build, make a new topic!
Partition Type = Free / Total
/fs/sd/MAP/ = 1.0M / 1.1G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.8M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 5.6M / 3.2G
/fs/sd/MAP/ = 25M / 3.2G
/fs/Nuance/ = 29M / 4.8G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 916M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 2.3G / 25G
Installed Packages
1U5T-14G421-BAJ
1U5T-14G421-BBJ
1U5T-14G421-BCJ
1U5T-14G421-BDJ
1U5T-14G421-BEJ
1U5T-14G421-BFJ
5U5T-14G391-AT
4U5T-14G422-BAG
4U5T-14G423-AC
1U5T-14G658-AH
I left out eastern and southern eu maps.
You are pushing it trying to fit all that on a 32GB APIM
You also clearly still have Gracenotes installed
FAQ:Gracenotes
You’ll need to be very patient with me,
First of all, what do gracenotes do, and can I live without them ?
if the ver. 22200 already in the APIM has 500mb of graceneotes and ver 22251 wants to install another 500mb of gracenotes then:
- What happens to the 22200 gracenotes ?
- Will I now have 1000mb of gracenotes ?
Album artwork
Just remove gracenotes like the FAQ said then install new over it
Ok, removed Gracenotes, and ver 22251 installed successfully.
I shall remember this for future use, many thanks.
