Navigation and geolocation are not working.
After updating SYNC 3 2.2 16280_PRODUCT to SYNC 3 3.4 22110_PRODUCT, the navigation stopped working and there is no geodata. The car’s clock is not working properly. Currently, the app displays an error stating that the XML file does not contain a valid engine control unit. I’m from Belarus. Please help.
Old SYNC Version: 2.2.16280
New SYNC Version: 3.4.22110
After turning on the engine, a window constantly appears stating that the application is being installed, but nothing happens.
VIN: WF0WXXGCEWHM79401
Модель APIM: Unknown
Тип APIM: Navigation
Размер APIM: 64GB
Свободное пространство APIM: 27G
Версия 3.4.22110 (5U5T-14G381-EZ)
06.03.2017 9:42:12 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 26M / 3.7G
/fs/Nuance/ = 29M / 5.0G
/fs/Nuance/ = 30M / 5.2G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 38M / 3.9G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 1003M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 27G / 54G
Installed Packages
1U5T-14G421-BHM
5U5T-14G391-AS
4U5T-14G422-BAM
4U5T-14G422-BBM
4U5T-14G422-BCM
4U5T-14G422-BDM
4U5T-14G423-AC
1U5T-14G658-AH
APIM AsBuilt
DE00: BLANK
DE01: BLANK
DE02: BLANK
DE03: BLANK
DE04: BLANK
DE05: BLANK
DE06: BLANK
Go to 2.2.17011 first, you’ll need to create the USB for that: HN1T-14G381-SA - SYNC 3 APIM Software (IVSU) Database - CyanLabs
After that run the interrogator to check the APIM model.
Why are you trying to use a build with known issues instead of 3.4.21265 or 3.4.23188 ?
Have you master reset?
Have you changed regions in the past?
He said he already updated to 3.4.
The following actions helped me.
“1. Insert a 32 GB flash drive. All data on it will be erased.
2. Open Syn3 Updater. In the settings, enable “Advanced options”.
3. In the settings, disable “Switch MY20 protection” — select “Disabled / not MY20”.
4. In the profile, specify the current version 3.4.22110, region EU, and navigation — enabled.
5. On the main screen, select the Downgrade mode, and the target version is 3.4.26057.
6. Make sure that the full set of EU cards is selected, and click “Burn”.”
