Hallo,
I tried several times to download data to 64GB Sandisc USB-Stick and always get the same failure message: “Not enough memory on the Data-Stick”
What did I wrong?
The files are downloaded to your local HDD before they are copied to your USB Drive, do you have enough storage space on your C:\ drive as you have your download path as the default of “Downloads folder”
Thank you for the screenshot.
There are 2 options:
A) your local HDD has not enough space for downloading the files
B) your USB does not really have 64GB (partitioning, counterfeit, or something on those lines)
Does Syn3Updater start creating the USB?.
If yes, then issue is likely B
If not, then A
My local SSD has not enough space!
I got preconfigured a small SSD for Windows Systsem and a large HDD for data.
But whole MS-Data (Office, Outlook, Users) is also saved here…
I Have to redirect the download to the second HDD drive or clean the SSD. Thanks a lot for all your answers!!
