Discussion topic for Organizr Auth on Cloudbox
Add the following to /opt/nginx-proxy/vhost.d/default For each service you want Organizr Auth on create a file called service.domain.tld_location such as sonarr.domain.tld_location with the following content If you want a failsafe BASIC auth for things like nzb360 create a htpasswd file at /opt/nginx-proxy/htpasswd/failsafe and add something similiar to below repeat the above process by creating a file for each service […]
Originally published at: Organizr Auth On Cloudbox - CyanLabs
