Please insert USB stick
What is your SYNC Region? EU
Do you have Navigation? No
What region is your SYNC APIM? EU
What was your old SYNC Version? 3.0.20204
What is your new SYNC Version? 3.4.21194
Do you have a error message, if so what is it? Please insert USB stick…
How did you update, Ford Website / CyanLabs Website / Syn3 Updater? Syn3 Updater
  • What version of Syn3 Updater did you use? 2.10.6.0 Stable
  • Have you read the documentation at https://cyanlabs.net/docs/syn3updater ? Yes
  • Please paste your log output or provide the URL to your log file below
Version: 3.0.20204
APPS=5U5T-14G381-ET_1627475308000.TAR.GZ
VOICE=5U5T-14G391-AP_1626914045000.TAR.GZ
; CyanLabs Syn3Updater 2.10.6.0 Stable - reformat  Mode - Sync 3.4.21194 EU
FILES (5)
1U5T-14G658-AG_1626915602000.TAR.GZ (56.8MB)
5U5T-14G381-ET_1627475308000.TAR.GZ (847.2MB)
5U5T-14G391-AP_1626914045000.TAR.GZ (1.5GB)
[09/10/2021 17:29:50] Selected Region: EU - Release: Sync 3.4.21194 - Map Version: Non Nav APIM
[09/10/2021 17:29:50] Install Mode: Auto-Detect (reformat) Forced: False
[09/10/2021 17:29:50] MY20 Protection: Auto-Detect
[09/10/2021 17:29:50] Formatting USB drive
[09/10/2021 17:29:50] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[09/10/2021 17:29:58] Checking Existing File: 1u5t-14g386-cb.tar.gz
[09/10/2021 17:29:59] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[09/10/2021 17:29:59] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[09/10/2021 17:30:01] Validated: 1U5T-14G658-AG_1626915602000.TAR.GZ (Skipping Download)
[09/10/2021 17:30:01] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[09/10/2021 17:30:25] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[09/10/2021 17:30:25] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[09/10/2021 17:31:03] Validated: 5U5T-14G381-ET_1627475308000.TAR.GZ (Skipping Download)
[09/10/2021 17:31:03] Checking Existing File: 5U5T-14G391-AP_1626914045000.TAR.GZ
[09/10/2021 17:31:30] Validated: 5U5T-14G391-AP_1626914045000.TAR.GZ (Skipping Download)
[09/10/2021 17:31:30] Preparing USB drive
[09/10/2021 17:31:30] Checking Existing File: 1u5t-14g386-cb.tar.gz
[09/10/2021 17:31:30] Copying: 1u5t-14g386-cb.tar.gz
[09/10/2021 17:31:31] Validating: 1u5t-14g386-cb.tar.gz
[09/10/2021 17:31:31] Copied: 1u5t-14g386-cb.tar.gz
[09/10/2021 17:31:31] Checking Existing File: 1U5T-14G658-AG_1626915602000.TAR.GZ
[09/10/2021 17:31:31] Copying: 1U5T-14G658-AG_1626915602000.TAR.GZ
[09/10/2021 17:31:35] Validating: 1U5T-14G658-AG_1626915602000.TAR.GZ
[09/10/2021 17:31:37] Copied: 1U5T-14G658-AG_1626915602000.TAR.GZ
[09/10/2021 17:31:37] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[09/10/2021 17:31:37] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[09/10/2021 17:33:14] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[09/10/2021 17:33:38] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[09/10/2021 17:33:38] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[09/10/2021 17:33:38] Copying: 5U5T-14G381-ET_1627475308000.TAR.GZ
[09/10/2021 17:35:32] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[09/10/2021 17:36:01] Copied: 5U5T-14G381-ET_1627475308000.TAR.GZ
[09/10/2021 17:36:01] Checking Existing File: 5U5T-14G391-AP_1626914045000.TAR.GZ
[09/10/2021 17:36:01] Copying: 5U5T-14G391-AP_1626914045000.TAR.GZ
[09/10/2021 17:39:34] Validating: 5U5T-14G391-AP_1626914045000.TAR.GZ
[09/10/2021 17:40:29] Copied: 5U5T-14G391-AP_1626914045000.TAR.GZ
[09/10/2021 17:40:29] Generating reformat.lst
[09/10/2021 17:40:29] Generating autoinstall.lst
[09/10/2021 17:40:29] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Please provide any further details below
Tried to update using the Syn3 Updater and got as far as insert USB stick. Have tried 3 different USB sticks. Have tried the USB stick in the 2 USB ports. Checked that the USB’s have power by plugging in iPhone. Have also tried disconnecting the battery for 10-15 mins to see if that made any difference.
Is there anything else you can suggest I try?
Thanks
Tom
Read this tutorial, it might help…
Tutorial: Sync 3.4 NON-NAV APIM: Failure to Update to Newer Version Sync 3.4 - Ford / Guides & Info - CyanLabs Official Community
Do you have a screenshot of the message?, I just want to be sure I’ve understood correctly. Also, create an interrogator log to see how much freespace the unit has.
@F150Chief , he already is on 3.0, so reformat seems ok.
I misread the version…this should just work
@TOMFIESTA18 ,
Did you resolve this issue?
This topic was automatically closed 5 days after the last reply. New replies are no longer allowed.
