The gui shows correct settings but apparently doesn’t actually use them unless you first change them to something else first, and then change them back.
2nd screen header correctly shows it didn’t accept the navigation setting, but shows the region as correct even though it really isn’t, until you toggle it once. Just opening the dropdown and reselecting the same as already shown does not actually set it.
Can you provide screenshots of main tab and configuration tab?.
Can you provide a log?.
Is this a fresh install of Syn3updater or you are an old user that got updates along the way?.
Also, I’m moving this thread into the correct section since this has nothing to do with Sync3
