Hello.
I have two questions.
1: There is no “DONTINDX.MSA” on the stick - do I not need it?
2: In the “AUTOINSTALL” there is only item 1-U5T-14G386-CB
Will the autoinstall be automatically rewritten for the rest during the update?
Thanks for the answers!
Hi, No reason to question it.
Thats exactly how it should be, autoinstall.lst is used to install the reformat tool then the reformat.lst is used to do the rest.
DONTINDX.MSA is not important it purely tells Sync “DONT INDEX” as in don’t scan it for media
(that said i will add it to the next realease because i may aswell)
Hello.
Thank you for the information. I added the “DONTINDX.MSA” myself. The update went perfectly. Thank you for your effort. Good work!
