Hi everyone, nice meet you here. First time poster but long time fan of the board. I have a 2017 Lincoln Continental, it was built to Chinese spec and as such the APIM is Chinese as well. I wanted to reformat/reflash the APIM and ACM in order to get EU maps and languages working on the car. I first wanted to reflash the APIM and ACM before starting on the upgrade of sync (orginally it ran on Sync 3 v. 2.2.16280). I managed to change all the APIM and ACM parameters from Asia to EU and Germany (where I live). After that I inserted the prepared usb stick with the cutdown maps to install. I used the sync updater tool to make the stick. My settings were as can be seen in the screenshot. However, when I insert the USB, I never get a prompt that it was detected and as such the install was started… like I should get. I decided to take the car for a drive as maybe the file was parsing or something like that but after 45 minutes… nothing… no notification no prompt… nothing. Then I park the car and remove the usb and do an ignition cycle, I get a message saying that some functions are disabled as there is an install running, do not remove the stick and keep the car running. There however is no progress bar and the stick was not in the unit. I then again reinsert the stick but…nothing. No change, still no notification that it is doing something. Any ideas? Could be that this way of upgrading does not work with Chinese spec APIMs? BTW after the reboot I did see that I managed to change the region of the APIM as it now had European languages and some slightly different warning prompts as compared to the Chinese English prompts. But the version was not upgraded. Another BTW, the whole install file on the stick (in the syncmyride folder) was about 11 gb. I wanted to update to version 3.4.22110.
Once again this is not a Chinese replica APIM that you can buy online, but this is an actual orginal Lincoln fitted APIM as the car was built for the Chinese market.
Any tips? Please help!
The stick I am using is a usb 3.2 enabled intenso speedline 256 gb stick (thought to buy a big one, since I did not have a 32 gb one lying around).
Thanks to anyone that can help! Keep up the good work.
SYNC Region: China
Navigation Variant: Yes
Old SYNC Version: 2.2.16280
New SYNC Version: 3.4.22110
It does not indicate that the update is running, but after I restart the APIM it says there was an update bein processed.
Version: 2.2.16280
Region: CN
Model: Intenso Speed Line USB Device
FileSystem: FAT32
VOICE=5U5T-14G391-AS_1644006548000.TAR.GZ
MAP=1U5T-14G421-BFJ_1644010644000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAG_1644245686000.TAR.GZ
; CyanLabs Syn3Updater 2.11.4.0 Stable - reformat Mode - Sync 3.4.22110 EU
FILES (10)
1u5t-14g386-cb.tar.gz (8,5MB)
5U5T-14G391-AS_1644006548000.TAR.GZ (1,5GB)
1U5T-14G421-BFJ_1644010644000.TAR.GZ (2,4GB)
4U5T-14G422-BAG_1644245686000.TAR.GZ (2,3GB)
[24-8-2022 12:40:32] Selected Region: EU - Release: Sync 3.4.22110 - Map Version: EU - 2022-08-24 - 1661337368
[24-8-2022 12:40:32] Install Mode: Auto-Detect (reformat) Forced: False
[24-8-2022 12:40:32] MY20 Protection: Auto-Detect
[24-8-2022 12:40:32] Formatting USB drive
[24-8-2022 12:40:32] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[24-8-2022 12:40:40] Checking Existing File: 1u5t-14g386-cb.tar.gz
[24-8-2022 12:40:40] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[24-8-2022 12:40:40] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[24-8-2022 12:40:42] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[24-8-2022 12:40:42] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[24-8-2022 12:40:46] Validated: 5U5T-14G381-EZ_1652218180000.TAR.GZ (Skipping Download)
[24-8-2022 12:40:46] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24-8-2022 12:40:46] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[24-8-2022 12:40:46] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[24-8-2022 12:40:52] Validated: 5U5T-14G391-AS_1644006548000.TAR.GZ (Skipping Download)
[24-8-2022 12:40:52] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 12:40:52] Downloading: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 12:40:52] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 12:40:52] Downloaded: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 12:40:52] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[24-8-2022 12:41:00] Validated: 1U5T-14G421-BAJ_1644010894000.TAR.GZ (Skipping Download)
[24-8-2022 12:41:00] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[24-8-2022 12:41:02] Validated: 1U5T-14G421-BBJ_1644008981000.TAR.GZ (Skipping Download)
[24-8-2022 12:41:02] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 12:41:02] Downloading: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 12:50:12] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 12:50:21] Downloaded: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 12:50:21] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 12:50:21] Downloading: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 12:57:48] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 12:57:56] Downloaded: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 12:57:56] Preparing USB drive
[24-8-2022 12:57:56] Checking Existing File: 1u5t-14g386-cb.tar.gz
[24-8-2022 12:57:56] Copying: 1u5t-14g386-cb.tar.gz
[24-8-2022 12:57:56] Validating: 1u5t-14g386-cb.tar.gz
[24-8-2022 12:57:56] Copied: 1u5t-14g386-cb.tar.gz
[24-8-2022 12:57:56] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[24-8-2022 12:57:56] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[24-8-2022 12:58:26] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[24-8-2022 12:58:34] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[24-8-2022 12:58:34] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[24-8-2022 12:58:34] Copying: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[24-8-2022 12:59:11] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[24-8-2022 12:59:20] Copied: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[24-8-2022 12:59:20] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24-8-2022 12:59:20] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24-8-2022 12:59:22] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24-8-2022 12:59:23] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[24-8-2022 12:59:23] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[24-8-2022 12:59:23] Copying: 5U5T-14G391-AS_1644006548000.TAR.GZ
[24-8-2022 13:00:28] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[24-8-2022 13:00:45] Copied: 5U5T-14G391-AS_1644006548000.TAR.GZ
[24-8-2022 13:00:45] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 13:00:45] Copying: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 13:00:45] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 13:00:45] Copied: 1U5T-14G424-BL_1646159765000.TAR.GZ
[24-8-2022 13:00:45] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[24-8-2022 13:00:45] Copying: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[24-8-2022 13:02:19] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[24-8-2022 13:02:43] Copied: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[24-8-2022 13:02:43] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[24-8-2022 13:02:43] Copying: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[24-8-2022 13:03:01] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[24-8-2022 13:03:05] Copied: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[24-8-2022 13:03:05] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 13:03:05] Copying: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 13:04:41] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 13:05:05] Copied: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[24-8-2022 13:05:05] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 13:05:05] Copying: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 13:06:40] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 13:07:04] Copied: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[24-8-2022 13:07:04] Generating reformat.lst
[24-8-2022 13:07:04] Generating autoinstall.lst
[24-8-2022 13:07:04] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
