Hi! I am performing a Sync 2 to 3 upgrade on my 2014 Ford Focus ST. The APIM I bought on Ebay is a Gen 3 (I think). After swapping, the display never fully shuts off when I exit the car, and the steering wheel controls no longer function.
My understanding is that this is because my APIM needs to be flashed with an older firmware to speak the older network language.
I have the Forscan 2.4.23 beta2 that supports firmware flashing, and I paid for the Forscan license so I could download firmware files. But I cannot figure out how to download GB5T-14G374-CD.vbf. My understanding is that this was a community fix to the memory maps to prevent bricking certain APIMs (mine included).
My new APIM part number is JS7T-14G370-GJG (with the hardware number HS7T-14G380-AB shown in Interrogator log and FORScan screen).
Can anyone please help me find the VBF files I need?
Much appreciated!
Old SYNC Version: 3.0.17276
New SYNC Version: 3.0.17276
N/A
It’s not usually a calibration flash. MOST the time(not always) it’s an AB setting where you have to set a setting in the APIM to CEGA 1.2 when the Focus is a CEGA 1.2 vehicle. Things wont communicate correctly if this is set wrong especially when it’s set to CEGA 1.3.
Appreciate the fast response! I will go out to the car and double check the current APIM as-factory data. I remember changing a field to CEGA 1.2, but are you suggesting there are multiple settings to change for this to work?
My car speaks CEGA 1.2, but this donor unit was from a 2018 Escape and currently speaks C1MCA/CEGA1.3.
I appreciate you redirecting me to the correct solution. Last night I had thought I exhausted all the APIM settings. I guess I did something wrong. I started fresh with the factory APIM settings that were on the donor, then changed ONLY the illumination strategy to C1MCA and CGEA version to v1.2. Now the display is properly powering off!
One issue remains. The right-hand audio controls are no longer functioning. Trying to find the relevant setting now…
Thats great to hear. The steering wheel controls could also be from a SCCM setting. They put in a setting for each steeringwheel pack type. There is a chance now that you have a new APIM with more features it either needs the pack changed or the AB setting for the pack updated or maybe even both.
I managed to get the steering wheel controls working now too. I don’t remember exactly which AB parameter did the trick, to be honest, but I had to change one of the hex values.
Pretty much everything is working, minus some brief flickering when I change the dash brightness. I can live with that! Saved this as a new baseline.
Thank you for welcoming me into the community and assisting me so fast!
