VEHICULO: FORD KUGA 2019, TITANIO, 2.0
Hello everyone, when I bought the vehicle I saw that it did not have the navigation activated and the parking assistant could not be used either. I took it for warranty and sure enough they activated and parking assistant and on the SYNC screen, a grid that said NAVIGATION FAILURE, FORD could never fix the problem so I decided to do it on my own.
in the first attempt it threw an error and a red screen and after several attempts and software downloads it could not solve the problem. then I decided with version 3.4.19101 and the error appeared again but I was able to identify it and it was about a VOICE_NAV PACK: 4U5T-14G421-DG 3.2.20339, it was removed from the update and it finally worked. the problem i have now is that although the fm radio, maps, and all the other apps are working, it keeps restarting. I wanted to know if you have any solution for this problem. thank you
SYNC Region: ANZ
Old SYNC Version: 3.4.20136
New SYNC Version: 3.4.19101
RESTART SYNC
ESTE ES EL LOG
CYANLABS - ACTUALIZADOR SYN3 - V2.11.4.0
Rama:
Sistema operativo estable: Microsoft Windows 10 Home Single Language (2009)
CONFIGURACIÓN ANTERIOR
Versión: 3.4.20136
Región: ANZ
Navegación: Verdadero
Modo de instalación: Detección automática (degradación)
Modo de instalación anulado: Falso
Protección My20 habilitada: Desactivado
DETALLES DEL DESTINO
Modo:
Modelo de unidad: SanDisk Ultra Fit USB
Tamaño del dispositivo: 14,3 GB Sistema de archivos
: exFAT
Tipo de partición: MBR
Reformat.lst Voice = 5u5t
-14g391-dh_1563811775000.tar.gz gracenotes
= 4u5t-14g423-da_123696.tar.gz
apps = 5u5t-4g381-op_15555585337000.tar.gz voice_nav
= 4u5t -14G421-DAF_1615429515000.TAR.GZ
AUTOINSTALACION.LST
; CyanLabs Syn3Updater 2.11.4.0 Estable - Modo degradado - Sincronización 3.4.19101 ANZ
[SYNCGen3.0_ALL_PRODUCT] Item1
= HERRAMIENTA - GB5T-14G386-SC_85041.tar.gz
Item2 = APLICACIÓN - 4U5T-14G381-AN_1552583626000.TAR.GZ
Open2 = SyncMyRide\4U5T- 14G381-AN_1552583626000.TAR.GZ
Opciones = Instalación automática
[SYNCGen3.0_ALL] Artículo 1
= HERRAMIENTA DE REFORMATO - 1u5t-14g386-cb.tar.gz
Opciones = Instalación automática , Incluir, Transacción
ARCHIVOS (9)
1u5t-14g386-cb.tar.gz (8,5MB)
5U5T-14G391- DH_1563811775000.TAR.GZ (1GB)
4U5T-14G423-DA_123696.tar.gz (716,5MB)
5U5T-14G381-AP_1555085337000.TAR.GZ (891,2MB)
4U5T-14G422-DG_1615429,5GB.TARGZ0 (5U5T-14G422-DG_1615429,5GB.TARGZ0)
4U5T-14G421-DAF_1615429515000.TAR.GZ (4,6GB)
4U5T-14G424-DAF_1616778205000.TAR.GZ (1,6KB)
REGISTRO
[31/10/2022 11:42:53] Región seleccionada: ANZ - Versión: Sync 3.4.19101 - Versión del mapa: 2.20 (2020) - ANZ, SA y TW
[31/10/2022 11:42:53] Modo de instalación: Detección automática (degradación) Forzado: Falso
[31/10/2022 11:42:53] Protección MY20: Desactivado
[31/10/2022 11:42:53] Formateo de la unidad USB
[31/10/2022 11 :42:53] Recreación de la tabla de particiones como MBR y formateo como ExFat en la unidad USB seleccionada
[31/10/2022 11:43:03] Comprobación del archivo existente: 4U5T-14G381-AN_1552583626000.TAR.GZ
[31/10/ 2022 11:43:15] Validado: 4U5T-14G381-AN_1552583626000.TAR.GZ (Descarga omitida)
[31/10/2022 11:43:15] Comprobación del archivo existente: GB5T-14G386-SC_85041.tar.gz
[31/10/2022 11:43:15] Validado: GB5T-14G386-SC_85041.tar.gz (Omitir descarga)
[31/10/2022 11:43:15] Comprobación del archivo existente: 1u5t-14g386-cb.tar .gz
[31/10/2022 11:43:16] Validado: 1u5t-14g386-cb.tar.gz (Omitir descarga)
[31/10/2022 11:43:16] Comprobación del archivo existente: 5U5T-14G391-DH_1563811775000 .TAR.GZ
[31/10/2022 11:43:37] Validado: 5U5T-14G391-DH_1563811775000.TAR.GZ (Descarga omitida)
[31/10/2022 11:43:37] Comprobación de archivo existente: 4U5T-14G423 -DA_123696.tar.gz
[31/10/2022 11:44:03] Validado: 4U5T-14G423-DA_123696.tar.gz (Omitir descarga)
[31/10/2022 11:44:03] Comprobación de archivo existente: 5U5T -14G381-AP_1555085337000.TAR.GZ
[31/10/2022 11:44:12] Validado:5U5T-14G381-AP_1555085337000.TAR.GZ (Descarga omitida)
[31/10/2022 11:44:12] Comprobación del archivo existente: 4U5T-14G422-DG_1615429764000.TAR.GZ
[31/10/2022 11:44:54] Validado: 4U5T-14G422-DG_1615429764000.TAR.GZ (Descarga omitida)
[31/10/2022 11:44:54] Comprobación del archivo existente: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[31/10/2022 11:46: 20] Validado: 4U5T-14G421-DAF_1615429515000.TAR.GZ (Descarga omitida)
[31/10/2022 11:46:20] Comprobación del archivo existente: 4U5T-14G424-DAF_1616778205000.TAR.GZ
[31/10/2022 11: 46:20] Validado: 4U5T-14G424-DAF_1616778205000.TAR.GZ (Omitir descarga)
[31/10/2022 11:46:20] Preparando unidad USB
[31/10/2022 11:46:20] Comprobación del archivo existente: 4U5T-14G381-AN_1552583626000.TAR.GZ
[31/10/2022 11:46:24] 4U5T-14G381-AN_1552583626000.TAR.GZ existe y se validó correctamente , omitiendo copia
[31/10/2022 11:46:24] Verificando archivo existente: GB5T-14G386-SC_85041.tar.gz
[31/10/2022 11:46:24] GB5T-14G386-SC_85041.tar.gz existe y validado con éxito, omitiendo la copia
[31/10/2022 11:46:24] Verificación del archivo existente: 1u5t-14g386-cb.tar.gz
[31/10/2022 11:46:25] 1u5t-14g386-cb.tar .gz existe y se validó correctamente, omitiendo la copia
[31/10/2022 11:46:25] Comprobación del archivo existente: 5U5T-14G391-DH_1563811775000.TAR.GZ
[31/10/2022 11:46:34] 5U5T-14G391- DH_1563811775000.TAR.GZexiste y se validó correctamente, omitiendo la copia
[31/10/2022 11:46:34] Comprobación del archivo existente: 4U5T-14G423-DA_123696.tar.gz
[31/10/2022 11:46:41] 4U5T-14G423-DA_123696. tar.gz existe y se validó con éxito, omitiendo la copia
[31/10/2022 11:46:41] Comprobando el archivo existente: 5U5T-14G381-AP_1555085337000.TAR.GZ
[31/10/2022 11:46:41] Copiando: 5U5T -14G381-AP_1555085337000.TAR.GZ
[31/10/2022 11:48:12] Validando: 5U5T-14G381-AP_1555085337000.TAR.GZ
[31/10/2022 11:48:20] Copiado: 5U5T-14G385-08_1533570_AP_1533570 .TAR.GZ
[31/10/2022 11:48:20] Comprobación del archivo existente: 4U5T-14G422-DG_1615429764000.TAR.GZ
[31/10/2022 11:48:20] Copia: 4U5T-14G422-DG_1615429764000.TAR .GZ
[31/10/2022 11:51:44] Validando: 4U5T-14G422-DG_1615429764000.TAR.GZ
[31/10/2022 11:51:58] Copiado: 4U5T-14G422-DG_1615429764000.TAR.GZ
[31/10 /2022 11:51:58] Comprobando archivo existente: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[31/10/2022 11:51:58] Copiando: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[31/10/2022 12:00:30] Validando: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[31/10/2022 12:01:12] Copiado: 4U5T-14G421-DAF_1615429515000.TAR.GZ
[31/10/2022 12:01: 12] Comprobación del archivo existente: 4U5T-14G424-DAF_1616778205000.TAR.GZ
[31/10/2022 12:01:12] Copia: 4U5T-14G424-DAF_1616778205000.TAR.GZ
[31/10/2022 12:01:12] Validando:31
_ _
_
_ /10/2022 12:01:12] Generando autoinstall.lst
[31/10/2022 12:01:13] ¡TODOS LOS ARCHIVOS DESCARGADOS Y COPIADOS EN LA UNIDAD USB CON ÉXITO!
