Discussion topic for Settings Tab
The settings tab is a extremely important tab, here you configure the application, detailed information on each setting can be found below. Car Configuration These settings are profile based and can be different for each profile Here you must enter your current car configuration, entering this wrong will cause you issues. Setting Default Value Comments […]
Originally published at: Settings Tab - CyanLabs
