Soft Bricked my mom's EcoSport
Hi everyone, I wanted to update my mom’s 2019 EcoSport from Sync 3.0.23219 to Sync 3.4.26057, but I didn’t realize I had Navigation selected originally. So when I plugged it in, it said it finished updating, and the car screen went black. Before I did this, I ran an interrogator log and found out it is NOT MY20. I’ve been looking on here and saw that a few people have had similar issues and they said to rewrite the USB without navigation, which I did, but it still won’t work. I made sure it says forced reformat as well, but it still isn’t doing anything. The lights around the USB ports come on for a while, and then go back off. The light on the USB drive itself is not flashing. I’ve also tried 3 different USBs to make sure it’s not that.
I also noticed just now that even though I selected forced reformat, Syn3 Updater is still adding the DONTINDX.MSA and the autoinstall.lst to the root. I deleted them, but my mom won’t let me retry it in case I mess up her car more… She wanted me to ask on here first to get a second opinion before trying anything else. I feel so bad, so if anyone could help us out, that would be amazing. I can also attach the interrogator log if anyone would like that. Thank you.
Old SYNC Version: 3.0.23219
New SYNC Version: 3.4.26057
No error message in Syn3 Updater
Version: 3.0.23219
Install Mode Overridden: True
FileSystem: FAT32
Partition Type: GPT
APPS=NU5T-14G381-AE_1778770590000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat FORCED  Mode - Sync 3.4.26057 NA
FILES (5)
NU5T-14G381-AE_1778770590000.TAR.GZ (869.9MB)
[9/4/2026 9:06:02 PM] Selected Region: NA - Release: Sync 3.4.26057 - Map Version: Non Nav APIM
[9/4/2026 9:06:02 PM] Install Mode: reformat (reformat) Forced: True
[9/4/2026 9:06:02 PM] MY20 Protection: Disabled / Not MY20
[9/4/2026 9:06:02 PM] Formatting USB drive
[9/4/2026 9:06:02 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[9/4/2026 9:06:10 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[9/4/2026 9:06:10 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[9/4/2026 9:06:10 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/4/2026 9:06:10 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[9/4/2026 9:06:10 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/4/2026 9:06:11 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[9/4/2026 9:06:11 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/4/2026 9:06:13 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[9/4/2026 9:06:13 PM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[9/4/2026 9:06:16 PM] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[9/4/2026 9:06:16 PM] Preparing USB drive
[9/4/2026 9:06:16 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[9/4/2026 9:06:16 PM] Copying: 1u5t-14g386-cb.tar.gz
[9/4/2026 9:06:17 PM] Validating: 1u5t-14g386-cb.tar.gz
[9/4/2026 9:06:17 PM] Copied: 1u5t-14g386-cb.tar.gz
[9/4/2026 9:06:17 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/4/2026 9:06:17 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/4/2026 9:06:18 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/4/2026 9:06:18 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[9/4/2026 9:06:18 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/4/2026 9:06:18 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/4/2026 9:07:06 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/4/2026 9:07:18 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[9/4/2026 9:07:18 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/4/2026 9:07:18 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/4/2026 9:08:27 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/4/2026 9:08:43 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[9/4/2026 9:08:43 PM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[9/4/2026 9:08:43 PM] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[9/4/2026 9:10:30 PM] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[9/4/2026 9:10:56 PM] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[9/4/2026 9:10:56 PM] Generating reformat.lst
[9/4/2026 9:10:56 PM] Generating autoinstall.lst
[9/4/2026 9:10:56 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Do you have forscan and an adapter?
If so, share the APIM model.
Is the unit totally dead? Like no sound at all?.
Is the screen black or the backlight is on?.
This looks like you reformatted a MY20 unit…
Those 2 files should be there, 1 tells Sync3 to not try to index the contents of the tar balls.
The other is there to tells the OS what packages to install in what order.
Hey, thank you for replying. I don’t have forscan, but I did do an interrogator log before it was bricked if that helps. It’s telling me the model is JK2T-14G371-BDD. The screen is completely black, I’m pretty sure I see no backlight on it.. We can hear the door chimes and stuff, and there are lights around the console, but other than that no. The only sign of life I can tell is the lights around the USB ports, which turn on when I do fast forward and power, but then turn back off after about a minute. The log could have lied to me, but it told me it wasn’t MY20… This was a used car as well, so we have no way of knowing if it was replaced before.
Here is the Interrogator log:
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2026-09-01” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>MAJ3S2GE9KC304312</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNC</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseJR3T-14G381-AY</d2p1:Response>
</d2p1:DID>
d2p1:Response4a5233542d3134473339312d424600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Responsec673651f</d2p1:Response>
</d2p1:DID>
d2p1:Responsed4671300</d2p1:Response>
</d2p1:DID>
d2p1:Response2a2a0106400028060880</d2p1:Response>
</d2p1:DID>
d2p1:Response55530104c082018028800005</d2p1:Response>
</d2p1:DID>
d2p1:Response0000010000</d2p1:Response>
</d2p1:DID>
d2p1:Response00000082070001</d2p1:Response>
</d2p1:DID>
d2p1:Response1900190026ac</d2p1:Response>
</d2p1:DID>
d2p1:Response40</d2p1:Response>
</d2p1:DID>
d2p1:Response0e04330000000080e80000565669006b</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-GB5T-14G371-DG</d2p1:Response>
</d2p1:DID>
d2p1:ResponseH1BT-14G380-AB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseJK2T-14G371-BDD</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G375-BB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseN1520031</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G374-DG</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Response60:b6:e1:3e:5e:1e</d2p1:Response>
</d2p1:DID>
d2p1:Response60:b6:e1:3e:5e:1f</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2026-09-01T16:20:51+00:00” RAM=“417148928” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/usb0/” total=“29G” available=“29G”/>
<d2p1:PartitionHealth type=“/fs/tmpfs/” total=“128M” available=“127M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.3G” available=“5.4M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1024M” available=“692M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1024M” available=“40M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“4.2G” available=“2.7G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
oh interesting, thank you for letting me know
Thank you for the information, the interrogator log is even better.
You are the first one to come across that APIM model, there’s no reference for that P/N in our hw db, and there’s a single hit for that in our forums: this thread.
This leads me to believe the unit is not original and has been replaced (possible recently) for a MY20 unit.
The only way to confirm this is to unmount the unit and check the sticker on its back.
Would you be able to do so?.
No, I am sorry, my mom would never let me do that lol. At this point, I would just like to get the screen back to its original function if we can.. Is there anything else I could try, or am I screwed?
Without knowing the model it’s hard to say, but based on what I learned from this thread the unit is MY20 and is basically bricked.
I’m so confident that I’ve manually added that model as MY20 so that others won’t be able to proceed unless they contact us.
As for your case, if it’s really a MY20 unit, your options are limited (and require physical access to the unit).
If you ever see the sticker on its back, please reach out and share a picture of it to confirm if it’s my20 or not before going down that route.
Alright, I might see if we can do that. My mom wants to ask, if we go to Ford and try to fix it under warranty, would they know we used CyanLabs? We have an extended warranty, so it wouldn’t cost much as long as it doesn’t void it.
You mentioned the car is used and from 2019, I doubt Ford has it covered, but you should know.
Can you play dumb?, of course you can. “It just died”, and that’s it.
Can a technician realize what happened?, yes.
Will they spend the time to reach that conclusion?, hard to say (but I would say, no).
So that’s one alternative, it’s up to you.
Personally, if you got the car from a person or small business, I would not go to them asking for a solution or refund, it was not their fault, right?..
As for the Ford (big company) approach, well, that’s different…
My mom was looking into maybe buying some kind of scanner, like an OBDLink EX or a Vgate Vlinker FS. If we use forscan, will it at least possibly show us what the dealership might see so we can determine if it will be covered under warranty or not before we take it there?
Don’t waste time or money on that. The only one that will tell you if it’s covered or not by the warranty is the one that issued the warranty.
You are not the first one to brick an APIM trying to update it, I would say Ford knows about it at this point. Would a dealer know/care and investigate?, hard to say.
But that’s me… Of course, it’s your call.
Since you are in NA, you can consider contacting @NaviUpgrade , he used to provide a recovery service for about 200USD I believe. I’m not sure if he’s still active, but that’s another option for you to consider.
Alright, we’ll see what we can do.. Thank you so much for your help with all of this.
That’s 100% for sure a replacment model. It’s bricked.
well shit. at least I know now. thank you
If you choose to replace it yourself you will need Forscan to update the AB info on it so it will work right.
If you buy a used one make sure it can be reuturned but there are a few people on here than can unbrick them and sell you replacments also. @SFRANCO is one of them.
The APIM is not to hard to get to. It’s behind the IPC.
2019 ford ecosport APIM replacment - Search
Thanks @bill32399
