After doing my sync 1 to sync 3 swap and manually editing all apim values my sony panel buttons backlights no longer work, I have tried messing with illumination strategys but havent figured it out. Any idea how to solve this?
Old SYNC Version: 3.4
none
APIM AB values have no effect on the FCIM lighting. In most cases this command originates from the BCM but it is also possable you have a wiring issue. Hard to tell since you neglected to include the vehicle year and model.
Ford does not support this so it cannot be an offical Ford update.
